02-02-2009, 17:16 | #5 (permalink) |
No Life Poster Join Date: May 2008 Location: arth'*****
Member: 776884 Status: Offline Sonork: techno-gsm Thanks Meter: 152 | u didn't give info abt the condition of ur phone a water damaged or what ?? mabe u must check shoorting 4 ex: there a short in pf try clean up a baord or rehot it but be careful................good luck. |
02-03-2009, 20:22 | #9 (permalink) |
Freak Poster Join Date: Aug 2006 Location: Greatwall Center™ Age: 43
Member: 325816 Status: Offline Thanks Meter: 31 | A slight broken or bad battery connector can cause this problem.When u flashing ur cable tightly binds with the Connector cause no problem.It happens ,that does not mean i m 100% right. |
02-03-2009, 22:06 | #10 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | brot3r its power ic fault rebal or rehot it convrt to normal mode frm box software if go sm timez n nt then its 100% pwr IC i had also this fault and i solved it with reball power IC also custmr was angry y i opened d phone but i hav to make it O.K |
02-03-2009, 22:14 | #11 (permalink) |
No Life Poster Join Date: Jan 2006 Location: THE GREAT :::LOVELY:::PAKISTAN
Member: 226363 Status: Offline Sonork: 03--4899925 Thanks Meter: 569 | full erase and flash with latest version and ur phone is showing local mode with fbus cable or not and also show ur flash LOG or on ur phone without base |
kp320 flashing complete but not powering on | GSMBALOCH | Infinity-Box | 3 | 06-30-2010 17:44 |
1110i, 1600, Flashing finish but not power on (SOLUTION) | Dooha_Bd | Nokia Hardware & Hardware Repair | 3 | 01-25-2010 16:44 |
nokia 1600 and 1208 flashes ok but not power on | vinkle | Nokia Hardware & Hardware Repair | 3 | 08-19-2009 09:04 |
V500 flash completed but not power on. Help | fromdesert | Motorola P2k | 1 | 12-10-2005 11:30 |
