Old 05-15-2006, 16:10   #1 (permalink)
anjella's Avatar
Member: 156882
Thanks Meter: 12
7610 white screen?
Hi , i have a nokia 7610 with white screen, the phone is working and can recieve call, i tried to replace lcd it will just work for just a while then white screen again. pls help
Old 05-15-2006, 18:04   #2 (permalink)
Member: 70796
Thanks Meter: 17
Look here and solve your problem:
https://forum.gsmhosting.com/vbb/f148/7610-white-screen-257943/
LAT
The Following User Says Thank You to kg2004 For This Useful Post:
Old 05-16-2006, 08:29   #3 (permalink)
lahoot's Avatar
Member: 229987
Sonork: 100.1602834
Thanks Meter: 193
br resold its uem ic if not succes then full flash it on ufs....
Old 07-19-2006, 10:48   #4 (permalink)
Member: 135983
Thanks Meter: 19
i think thaaaaaaaaaaat from lcd conectour
Old 07-19-2006, 15:30   #5 (permalink)
Member: 114633
try chack lcd conector if ok try change the lcd ic
Old 06-01-2009, 03:37   #6 (permalink)
Member: 1042268
Smile
have you tried reheating the LCD IC?check the lcd connector as well..
7610 white screen nasir shiwani Nokia Hardware & Hardware Repair 46 02-16-2010 06:22
7610 white screen all calls incoming outgoing flashed many version still white screen GSMBALOCH Nokia Hardware & Hardware Repair 7 06-01-2009 20:54
7610 White Screen then Turns off, Urgent msas Nokia Hardware & Hardware Repair 8 11-15-2006 03:34
7610 white screen after flashing a ppm MELME UFS2 + UFS3-Tornadoflasher 29 05-05-2006 01:53
Page generated in 0.16492 seconds with 9 queries
