1600 no mic, no ringer, no speaker I have got one 1600 with these problems. I check it i think it have converted from 1600b. But i have also flash it and also change its audio ic. but same condition. it mic ringer speaker not work. is there any solution. |
Plugin a headset to headset connector & test have audio or not ? If problem still remain then try to change the headset connector. Best regards |
Thanks but same problem. Please do any thing perfect. |
replace ic ringer bro |
rebol or change uem 10000000000000%solution for me . |
its just ic audio problem bro cek this first |
as i say its all points r ok. Becasue it is new set. I think it have problem in software like 3100b |
who will give me solution????? |
1600 1 Attachment(s) Quote:
try this good luck Attachment 187165 |
i do solution with nokia 1600 but problem is same i check mic ,mic points, handfree port every thing is ok |
check the voltage on spkr tips& micktips if no volttage then 100%uen problem. |
please check handsfree socket or its line ok think your problem will solve with in a munitte........ |
replase charging pin best solution brothers |
write full pm form original 1600 nokia. and also try to selftest by ufs or jaf results will guide you what is the fault in the phone. |
your problem is hardware br. replase charging pin change sound ic again properly plz ...... |
