Old 04-08-2009, 19:57   #1 (permalink)
p.suresh's Avatar
Member: 482019
Thanks Meter: 100
rpl means?
what is the meaning of rpl and how to write on jaf please explaie any one
Old 04-09-2009, 05:20   #2 (permalink)
jothi737's Avatar
Member: 369539
Sonork: 1584109
Thanks Meter: 32
What is ASK FILE? WHAT IS FLASH RPL?
A. as we all know ASK file contains, the ffg. IMEI_ESN and DATA. it's use to request for RPL[4a]. IMEI_ESN is too obvious it has the imei of the unit while DATA contains ASIC number plus the readed FLASH RPL ( if it's still valid, else it needs a new FLASH RPL. ) it's Re-enocded that why we cannot just see the FLASH RPL. we cannot write ASK file. to WRITE u will need a valid DCT4RPL file.
FLASH RPL, it has DATA1 this part is written to the FLASH IC w/c the firmware use to validate the imei and watchdog[4b] at UEM IC. if not the same. result would be auto-off (<32sec) or a bad imei ( ????????????4 ).
There is a site that will allow u to see the content of your ASK/RPL file..
Old Dct4 has pm208 it contains the FLASH RPL. but new dct4plus dont have it now on PM208. it's been protected from READING via PM. might still be possible to read via Loader way, thou...
The Following 2 Users Say Thank You to jothi737 For This Useful Post:
Old 04-09-2009, 05:30   #3 (permalink)
Member: 604978
Thanks Meter: 216
that was really good info thanks bro............
Old 04-09-2009, 05:37   #4 (permalink)
..::ohm::..'s Avatar
Member: 662678
Thanks Meter: 2,539
ASK - used for RPL calculations
RPL - RPL is a structured programming language
MCU - Master control unit
PPM - Post Programmable Memory
PM - Permanent Memory
RPL File is file wich restore SP Data on BB5 fones in case u dont have Back up also is used to imei repair on BB5 fones with imie:1234567890134
RPL is needed when u try to unlock and the fone shows u this info:
CONFIG KEY:FFFFFFFFFFFFFFF or Counter 10/10, 3/3
The Following 3 Users Say Thank You to ..::ohm::.. For This Useful Post:
SIM restriction pending -- what does it mean? Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 07-17-2011 10:05
what means rpl ??????????? techno-gsm Nokia Base Band 5 ( BB-5 ) 5 03-26-2011 13:15
RPL means? how can i make back up of rpl of any phone? nofear99 Nokia Base Band 5 ( BB-5 ) 1 11-19-2009 05:10
Auto-RPL Backup,Write RPL, ASK to RPL for BB5 matrix05300 HWK 0 02-28-2007 19:58
I mean pc guide for nokia 8210 linda Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-18-2000 20:49
Page generated in 0.32009 seconds with 9 queries
