1616-2c (RH-129) - convert to 1616 RM-125 2 Attachment(s) Hi, here's the solution to convert (USA) t-mobile 1616 models, and probably vice versa (normal 1616 to 1616-2c) (Method should be applicable to all similiar Infineon models - 1800, c1-00, etc etc.) 1. backup full PM 2. backup RPL, and on cyclone backup IMEI pm 3. Flash RH-125 firmware with desired lang. pack 4. write attached PM (for 900/1800MHz band, for rh-125) 5. check imei etc, if needed, write back original RPL / imei PM 6. change marked filter (check on image attached) from similiar model voila ... full signal bar, phone works normal. p.s. you can probably use filter from different models, i used from c1-00, but any dual-band filter same size/pinout should work. p.s.2 i missed thread title, it's RH-125, not rm-125 :) press THANKS button if this was usefull. have a nice day :D b.r. ALex |
I just tested this method and I get full signal after IMEI / RPL restore but I can't make / receive calls. Any hints ? Filter used is from another 1616 rh-125. WBR, gsm9l;) |
and recheck filter placement, maybe bad soldering. or ... first try other PM ... maybe just that's the problem, i used some generic one ... maybe not good for all hardware types. b.r. Alex |
[IMG]http://www.****************.com[/IMG] Quote:
Converting the 1616-2b ( RH126 ) and 1616-2c ( RH 129 ) to 1616-2 ( RH 125 ) without Here the conversion of the 1616 without having that to worry about to get a filter adequate SAW, Joselec http://thumbs.subefotos.com/5bb01e5f...4c58fec61o.jpg |
Broblem with Nokia 1616 Hi everyone I need unlock code for nokia 1616 simple mobile please the meid is 012569009506593 |
hy guys i have noika 1616-2b . . after unloking the signal not coming .. plz tel me the covertion of nokia 1616-2b rh 126 into nokia 1616 |
