12-13-2008, 09:17 | #1 (permalink) |
Freak Poster Join Date: Jun 2008
Member: 790563 Status: Offline Sonork: sayeedkhader Thanks Meter: 26 | 1650 dead while battery low thanks |
12-13-2008, 10:02 | #2 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Medan - Indonesia Age: 43
Member: 233686 Status: Offline Thanks Meter: 50 | try to flash it 1st n.......post ur flash log here if not solved ur problem...... |
The Following User Says Thank You to gm33223322 For This Useful Post: |
12-13-2008, 14:06 | #4 (permalink) | |
Insane Poster Join Date: Jun 2008 Location: F2K Mobile Solutions Age: 37
Member: 803104 Status: Offline Sonork: 100.1664442 Thanks Meter: 25 | Quote:
Try to kick the battery and charge. at the moment the phone went off i think the battery is low n then u have to kick n charge the battery wen i say kicking i mean u have to introduce some power to the battery in this case u have to use a universal charge to kick the battery or u can use any charger just cut off the last end n use the positive to the battery positive and the negative to the battery negative for 2 munites then remove and insert to phone n then charge. or clean battery connector well be for inserting it to the phone. | |
12-14-2008, 11:05 | #5 (permalink) |
No Life Poster Join Date: Aug 2006 Location: P A K I S T A N(+923149818013) Age: 33
Member: 326871 Status: Offline Sonork: down2 sky.up 2 the earth Thanks Meter: 636 | It can be ok by flashing. Dead 1650 need erasing first. After erasing flash it . Write pm . Unlock . Fact set. Mobile ok. |
The Following User Says Thank You to waji mobiles For This Useful Post: |
NOKIA 1110/1112/1600 Battery low SolutionNOKIA 1110/1112/1600 Battery low Solution | gsm junction | Nokia Hardware & Hardware Repair | 3 | 05-06-2013 13:02 |
nokia 1650 dead while i change the charging connector | parag4923 | Nokia Hardware & Hardware Repair | 9 | 11-30-2010 18:29 |
1650 battery low | billa2008 | Nokia Hardware & Hardware Repair | 1 | 10-27-2009 13:20 |
Siemens C35 shouting battery low while not | greenhat | Siemens Hardware Repair Area | 2 | 10-13-2005 10:01 |
