Old 10-25-2001, 01:06   #1 (permalink)
Member: 5364
Post 6210 Charging Solution
Charging voltage 100% ok but phone says "not charging"Removed & cleaned ,resoldered etc. system connector,ALL small charging components checked & double checked including charging uBGA.Still the same ...any ideas???? <img src="frown.gif" border="0"> <img src="frown.gif" border="0"> <img src="frown.gif" border="0">
Old 10-30-2001, 20:27   #2 (permalink)
Member: 2461
Thanks Meter: 22
I have just had the same problem on a 6210 of my m8's<br />It had blue led's fitted and part of the lower shielding had been cut away to access the bottom led's.<br />Here I found some print damage and a resistor missing (Broken from print)<br />It was a 4.7K <br />After repairing the track and replacing with a new resistor the handset charged perfectly.<br />Wish I had examined closely before checking around uBGA etc<br /> <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0">
Old 10-30-2001, 23:14   #3 (permalink)
Member: 7075
Post
[quote]Originally posted by cells r us:<br /><strong>Charging voltage 100% ok but phone says "not charging"Removed & cleaned ,resoldered etc. system connector,ALL small charging components checked & double checked including charging uBGA.Still the same ...any ideas???? <img src="frown.gif" border="0"> <img src="frown.gif" border="0"> <img src="frown.gif" border="0"> </strong><hr></blockquote>
Try changing the CHAPS and CCONT on phone. That usually helps. ; )
Old 06-30-2010, 15:25   #4 (permalink)
fazi52's Avatar
Member: 904326
Thanks Meter: 62
what all say different fault charging i have nokia 6210 which show 1.5v on battery point but not show charging what about this i ma using durastar battery but same
The Following User Says Thank You to fazi52 For This Useful Post:
6210 navi charging solution ? ajmal007 Nokia Hardware & Hardware Repair 2 08-12-2009 23:01
[PMP mp5 USB charging solution] Final solution For Mp5 convert to charge in Usb cord ali-xander™ Game Consoles & Mp3/4 , HD players 0 08-03-2009 06:09
5110 and 6210 charging problem? Abelardz23 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 11-18-2003 19:46
5110 and 6210 charging problem? Abelardz23 Sim Cloning and Scaning 2 10-22-2003 16:33
nokia 6210 charging all the time and 8210 no power on emmibox Nokia Hardware & Hardware Repair 0 08-30-2001 05:46
Page generated in 0.16052 seconds with 9 queries
