1650 not charging 1650 damaged with water shows not charging , the solution please |
thanks problem solved by removing |
1650 1650 Writing Error Pls....... Solu |
1650 1650 Local Mode Faild SOLU...............PLS:o:(:rolleyes: |
problem solved by removing which ic ?? pls give diagram |
helloo bro i have a nokia 1100 its same pro plz solve this.................. FRIENDS ONLINE COMMUNATIONS SHOP NO: 7 SOLDIER PLAZA CIVIL LINES JHELUM PAKISTAN CELL NO: 03215900343 |
please help thanks |
remove capasiter near bsi |
1650 not charging board is not water damage i wil change the part back side of charging connector pls help me |
1200,1208 1650 many set not charging is the socket conect unwill oso,, just remove n clearn n make sure that way can conect n rechange a new socket.. use the big bower gun type 3463,n put it 370-380 'c it will be change done on 20sec..i done all not charging by like this,,, good luck.. |
1202 not charging plz help |
if removing those capacitors doesn't solve the problem, writing full ATF PM solves the "Not Charging" error on 1650 |
