2100 contact service Hi ..., I have nokia 2100 with contact service problem ...., i flash it with knok with full flsh 2mb but the same ..., i use wintesla to detect the falut then i get eeprom tune checksum ....failed ..., i read a full flash from working phone and the reflash it again ....but the same ....can any one help ...? |
Open the phone and ceck for liquid damaged.;) |
Connect Mbus cable to phone, read phone info...then just reset sim locks, write imei, update FAID, make SFS. All should be ok. Firecell |
Firecell! Yes, I always do this in KNOK and is very very good!!!!!!!! |
AM HAVING PROBLEM TOO. |
any other solution ...? |
I don't know what is wrong with your phone, man. If you only flashed it and got CS, then just try other flash. Bear in mind - every time you changing MCU in 2100 it goes in CS - but you can remove it only by calculating IMEI, FAID and SIM LOCKS. Try if you need full flash contact me! Regards |
ok ... could u send me full flash to [email protected] ... |
full flash with prober flash this mean the full fls file near to the verission cuz mcu changes in 2100 is very bad you got contact service ... i have a trick but i m not resposible of it |
use knok for earse the fls and try to load the the fls file after you earse and remove battry for 5 second and install the battery and cable and flash it now with the prober fls for 2100 |
i try now works!!!!!!!!!!!!!!!!!! |
i have similar problem but mine displays contact provider, can any one help me out |
check ic voice and ic flash |
try to flash phone using banana prog choose 8210 and after that open lock by DDB |
