Old 05-07-2004, 00:10   #1 (permalink)
Member: 52430
Thanks Meter: 3
2100 no network
pls can someone give me a detailed
solution for 2100 no network problem
Old 05-07-2004, 16:55   #2 (permalink)
Bi0H4z4rD's Avatar
Member: 52560
Thanks Meter: 226
Maybe change PA?
The Following User Says Thank You to Bi0H4z4rD For This Useful Post:
Old 05-07-2004, 17:52   #3 (permalink)
Registered User
Member: 55575
Thanks Meter: 3
Also try Update FAID with Rolis soft.
Old 05-08-2004, 01:00   #4 (permalink)
leosedf's Avatar
Member: 33547
Thanks Meter: 17
also check the antenna switch
Old 09-11-2004, 22:58   #5 (permalink)
rajumobile's Avatar
Member: 54993
Thanks Meter: 47
First Identify its HW or SW, try manual network search if found then prob its SW.
Old 09-17-2004, 18:03   #6 (permalink)
Member: 68021
Thanks Meter: 11
check the txirq first, then check the txirq from hagar to hagar. plz use the scematic. the signal problem is not only in pa or antena swicht, but the cobba ic and ccont ic can make the signal drop.
Old 09-17-2004, 21:46   #7 (permalink)
Member: 76877
wht kind of signal problem and wat couse it to lose signal?
1.weak signal
2.flactuating signal
3.fake signal
4.logo only
5.indicator only
6.manual signal only
7.one bar signal only
what signal problem?
there are almost 12 kinds of signals problem,
ill wait for u to tell witch one?
or ill try to drop by ASAP to post all the posible technic i know.
respect coming from me
Old 09-18-2004, 00:39   #8 (permalink)
Registered User
flechazo's Avatar
Member: 39250
Thanks Meter: 64
Tr
-FAID By Rolis
-Change PA
-Change Antena swicth
........ReGards
Old 09-19-2004, 11:51   #9 (permalink)
Member: 79647
hi
chukky many times i do it go and falsh first than if u got logo only than open with help nokia rolis soft ware here u can change imiei also {ap date faid } if result is same than come on cooba {light heat}than check again if same than replace cobba but should be ok . if not come step by step {hagar pa intina sw try its 100> true do and tell me bye
Old 09-19-2004, 14:28   #10 (permalink)
::Yasir::'s Avatar
Member: 47281
Thanks Meter: 17
Quick set faid. or flash it!!
Old 10-25-2004, 12:07   #11 (permalink)
Member: 83893
I ve flashed it and still the same prob, no network at all, and phone arbitralily switches off...I ve made a phone call, but then no network since then...I am suspecting ccont..Any ideas?
Old 10-26-2004, 14:46   #12 (permalink)
Member: 76633
I loaded software nd updated faid then replaced ant swt, pf and cobba but the singnal dropping doesnt solve.
Old 10-26-2004, 16:06   #13 (permalink)
Member: 56369
Thanks Meter: 47
no network
Check the B+ of PA&RX section(filters,capacitors,resistors,etc)&cct may be open.
Old 10-26-2004, 16:44   #14 (permalink)
Member: 66225
Thanks Meter: 9
FAID By Rolis
-Change PA
-Change Antena swicth replace cobba
Old 04-05-2005, 02:47   #15 (permalink)
gama_cell99's Avatar
Member: 92067
Thanks Meter: 10
Some time CPU and flash chip IC can meke phone no network
The Following User Says Thank You to gama_cell99 For This Useful Post:
2100 no network after flash Mirken UFS2 + UFS3-Tornadoflasher 6 06-15-2009 22:18
nokia-2100 no network rajeshku_jn Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 11 06-14-2009 20:47
3310/2100 No network peraltech Nokia Hardware & Hardware Repair 5 01-19-2007 18:29
2100 No Network mattakins Nokia Hardware & Hardware Repair 12 12-03-2006 13:25
2100 no network after flash magnet Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 24 09-03-2004 07:59
Page generated in 0.22749 seconds with 9 queries
