11-20-2004, 16:29 | #3 (permalink) | |
Freak Poster Join Date: Nov 2003 Location: GSMWorld Age: 49
Member: 43758 Status: Offline Thanks Meter: 0 | Quote:
go to menu->phone settings->network settings and try to find out network manual and let us know what happened...we can sort it out after this checking... BR g****** | |
11-20-2004, 23:07 | #6 (permalink) |
No Life Poster Join Date: Sep 2002 Location: max232 chip
Member: 16036 Status: Offline Thanks Meter: 5 | hi 1: liquid damage phones WILL ALWAYS have problem/continues to rust all time 2: check is pa is ok, then antena switch 3:reball ccont 4:check hagar/coba for DRY JOINTS n also RUSTED PADS 5: measure 26mhz 6: check also b1200 ok should measure 32,768KHz 7:check filter like i say WATER DAMAGE very hard to repair in many cases,.also IF U DO will always coem back with OTHE RPROBLEM |
11-21-2004, 17:41 | #9 (permalink) |
No Life Poster Join Date: Sep 2003 Location: GermanY
Member: 38922 Status: Offline Thanks Meter: 35 | The best tip is from g****** above, why in world writing everyone lamer things?? First of all, he must check the manuel network search. It can be have some failures: IN MOST CASES: ---------------- After some times found all Networks (but cant login) >> Change P.A After 4-7 sek. comes "NO Network found" >> change P.A After some times comes "Vodafone, T-Mobile" >> change Diplexer (cause it found only GSM 900MHZ) After 30-1 min. comes" No Network found" >>change COBBA I won't 2 say its 100% so, but these r the most failures. It can be also the quarz etc. GreetZ |
11-21-2004, 18:49 | #10 (permalink) |
Member: 43758 Status: Offline Thanks Meter: 0 | @CyberoptiK Exactly!You are very right but HAGAR is also very important...I think is too much info at one time...step by step will be better let him what he was checked... BR g****** |
3310 network | GSM RAJ | Nokia Hardware & Hardware Repair | 3 | 07-16-2002 06:39 |
3310 network? | gsmsalers | Nokia Hardware & Hardware Repair | 8 | 07-04-2002 07:18 |
6210 & 3310 Network Signal only for few seconds | douda | Nokia Hardware & Hardware Repair | 6 | 06-25-2002 18:02 |
3310 network problem | emmyale | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 05-19-2002 09:40 |
3310 network problem | gsmkid | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-09-2001 21:21 |
