2100 not charging there is a nokia 2100 not charging with me please what do i do to rectify the problem |
2100 Not charging Check FUSE, CHAPS, CCONT. beware of water damage Yoda. |
@gbada pls do search u will find slotion for this problem and chang fuse if nothing try to reflash if nothing reheat charging ic if nothing chang charging ic ******************Azam**************** |
Flash a new Update. GreetZ |
Its a known Problem. First of all, flash a new Update with e.g twister, it will 8ß& ok, if not , check the Mechanic parts how azad writed down (above) GreetZ |
for haven sake ppl,this is a very commen problem of nokia fones,what is not charging?fone says not charging?or fone does not show any thing? in both cases it's hardware problem,FLASH FONE,is not the sulotion for evry thing, check fuse if ok then remove the cap located behinde the irda space or change it, Daanish |
Dear daan, i dont how you can so sure about it.. Please check your knowledge about the DCT3 - 2100 (NAM-2) BUGs. First of all, always Flash. Why should he waste the time with opening the fon, if that ain't a hardware problem..?? This is a Screenshot of Twister, look what Saras says: http://www.directupload.net/images/041122/M3EA8nCa.jpg If is after Flash not ok, then he can start with checking hardware parts. Respect |
