2100 simnotvalid I my nokia 21oo when i insert sim the network is not coming but after few seconds it restarts &showing simnot valid.i have erased the flashfile through ufs flashing it again &again but i cant rebuild imei.so my problem is not solved.plz help me |
flash it through geo flash.... |
try flash with gaf and rehot coba and try |
u have to change cobba ic. |
Right your problem is in cobba if not then flash ic |
or one of many capasitors around cobba is damaged. |
UFs cant solve that problem. Use Knok95 thenrun NokTool... |
check your cobba first mates! if no lucks, try to flash your phone, flash your phone using rolis(banana) calculate use noktool, read phone info change imei cl;ear sp locks updait faid softwarec reset |
You Can Repat Imi By Greven If Not Its Coba |
replace cobba and update faid in noktool and opensimlocks.. br |
yes perfect solution by MR. GSm_BLUE WBR salim |
the rit solution is flash it knok 95 and rebuild imei with nok tool |
ufs can solve this problem only thing u need to do is downgrade ur version & rebuild imei.If not able to do so use knok 95 software. ur problem will be solved 100% |
I think it Softwere problem 1st send info of 2100 I will solve ur problem Just flash it by 5.49 & pmm If softwere problem then solve other wise it is hardwere fault |
u unlock with nokia tool and change imei set will be ok 100%work by ARMICO MOBILES |
