Old 09-14-2006, 17:31   #1 (permalink)
Member: 231694
2300 low battry
dear Doctors,
pls i av a 2300 nokia phone, wen calling or on its own show low battry.
i av change the battry with a new one but still pasist. pls help.
lawal.
Old 09-14-2006, 18:24   #2 (permalink)
manyosa's Avatar
Member: 271974
Thanks Meter: 97
Originally Posted by masudlawal View Post
dear Doctors,
lawal.
Try to change pf and post the results.
Old 09-14-2006, 18:32   #3 (permalink)
Member: 58375
Thanks Meter: 12
change PA fone ll be fine
Old 09-14-2006, 20:19   #4 (permalink)
..::ArchitRaj::..'s Avatar
Member: 181696
Sonork: 100.107830
Thanks Meter: 5,406
dear Doctors,
lawal.
First change batery conecter...
if not ok then change PA
Raj
Old 09-15-2006, 02:50   #5 (permalink)
Member: 223959
Thanks Meter: 8
yup the only thing u need to do is change the pa if it do not work u need to change uem i got the same problem solved in more than 10 phones
Old 09-15-2006, 02:54   #6 (permalink)
Member: 223959
Thanks Meter: 8
change pa if u dont get result change uem i got result on more than 10 phones 100% tried and tested
Old 09-15-2006, 21:52   #7 (permalink)
ukmobilestore's Avatar
Member: 237646
Thanks Meter: 19
change the battery connector
Old 09-15-2006, 22:00   #8 (permalink)
Member: 275451
Thanks Meter: 84
Old 09-15-2006, 22:02   #9 (permalink)
Member: 237646
Thanks Meter: 19
dont need to change the pa you will need to change the change the battery connector
Old 09-20-2006, 19:27   #10 (permalink)
Member: 58375
Thanks Meter: 12
brother its 100% PA problem , battery connectors are fixed with boards in these sets so no need to change
Old 09-20-2006, 19:38   #11 (permalink)
Member: 106645
Old 09-21-2006, 06:52   #12 (permalink)
Member: 320675
check the batt connector with multitester,if it indicated low resistancy between terminal, changed it. otherwise it should be PA problem
Old 09-21-2006, 07:04   #13 (permalink)
gsm-iran's Avatar
Member: 188646
Thanks Meter: 76
hi br
change the batt connector ok
thanks Archit.raj......
Old 02-05-2008, 16:18   #14 (permalink)
Member: 369369
Thanks Meter: 15
change the pa the lagest black ship at the top of your phone at the left hand side.
Old 02-05-2008, 19:01   #15 (permalink)
Member: 515180
u need to change battery connecter i have solve this problem in same set yesterday and i think its 100% battery connecter problem
moto v3i low battry after some call sonuk Motorola Hardware Repair 1 09-21-2007 04:09
n620 always low battry tone Samsung Hardware Repair 6 06-15-2004 04:47
8210 always low battry in standby mode!!!!!!!! micmac Nokia Hardware & Hardware Repair 2 11-24-2002 19:16
8210 low battry tone Nokia Hardware & Hardware Repair 5 12-21-2001 04:18
Page generated in 0.20277 seconds with 9 queries
