2300 "Sim not valid" 2300 Switches on fine and when pin # is entered it reads "Sim not valid" what could be the cause of this and how to fix it? Thanx. |
Reflash it,or just unlock |
its it :) If u need something from flash file or software contact me by email here www.geocities.com/nestorenie best regards |
If the serial nuber is OK ,you can revive your phone by flashing IT! If the serial nuber is faulty or doesn't feet As I know ,in this case ,you can't do any thing ! In the featur perhaps !!!!!!! |
reflash it and change the IMEI. |
change IMEI on a DCT4 that easily!!!???? @abbeydguru, this must be a joke.... |
hi.. This is Mostly Fault in 1100 and 2300 Mobile. SO this is 1000% confirm your IMEI is goes to ????????????4 so u need Griffin Server to Rebuild the IMEI. Read Imei and then send to griffin server. When u read its ASK file first confirm it should be same as original. Otherwise after Rebuild the IMEI your Mobile is Restart after 2min. so if u got this problem so only 1 solution change it UEM chip. Best Regard's Muhammad Tahir www.tech-mobile.net |
changing IMEI with Griffin ??? |
not change but rebuild.... you must use the same IMEI |
woteva change or rebuild, but he made sense that is the solution actually |
Thanks for your help I'll give it a try and let you know the results. |
I've tried and couldn't change IMEI ????? still the same problem? Any more ways to fix this |
IMEI????????? you have to reheat or just replace UEM.... GD LUCK... |
hi... mate just read ask file through Griffin or Twister. This is not free solution u must buy Griffin log the price of 1log is $8 br Muhammad Tahir www.tech-mobile.net |
