Old 01-29-2007, 08:40   #1 (permalink)
Member: 232344
Thanks Meter: 7
2310 not charging
Hi to all
water damaged2310 now showing not charging?
any one give me solution.
The Following 2 Users Say Thank You to zafhal For This Useful Post:
Old 01-29-2007, 08:43   #2 (permalink)
Lhick's Avatar
Member: 333359
Thanks Meter: 91
Try to write1st good, PM, then Check components is OK...If OK, Damage part UEM.
The Following User Says Thank You to Lhick For This Useful Post:
Old 01-29-2007, 16:27   #3 (permalink)
MichieMax's Avatar
Member: 40758
Thanks Meter: 26
hi i have nokia 3100 when power on says restriction code undo any idea please help.thanks.
The Following User Says Thank You to MichieMax For This Useful Post:
Old 01-30-2007, 07:18   #4 (permalink)
Member: 330775
if it is"not charging" Try change to local mode in ufs box. If it is failed,problem may be in BSI path.Check the bsi,battery,then only UEM
check it yyyyaaaaarrrrrrrr
The Following User Says Thank You to Bijith 06 For This Useful Post:
Old 01-30-2007, 07:24   #5 (permalink)
Member: 432364
Thanks Meter: 270
Tri to change charging connector then also same its uem problem rehate
or change uem 100% slove.
B.r.
psunil.
The Following User Says Thank You to ..::Sunil::.. For This Useful Post:
Old 01-30-2007, 07:38   #6 (permalink)
Lhick's Avatar
Member: 333359
Thanks Meter: 91
Check IMEI if ?????????????? If not Unlock Phone, If ? need to change UEM.
Old 01-30-2007, 08:07   #7 (permalink)
Member: 432364
Thanks Meter: 270
Tri to patch in ufs. If get off in some time change uem.
B.r.
psunil.
Old 01-30-2007, 08:26   #8 (permalink)
Member: 232344
Thanks Meter: 7
Bijith but there is not problem of BSI and nor battery but what about UEM?
The Following User Says Thank You to zafhal For This Useful Post:
Old 01-30-2007, 08:36   #9 (permalink)
Member: 232344
Thanks Meter: 7
B.r.
psunil.
Okay Psunil but after reheat UEM i think set will be dead?
Old 01-30-2007, 08:49   #10 (permalink)
Member: 432364
Thanks Meter: 270
Heat there only where is charging part not full.
B.r.
psunil
Old 01-30-2007, 10:20   #11 (permalink)
capri's Avatar
Member: 396326
Thanks Meter: 229
@zafhal could you give me the picture for that 2310 or schematic diagram?
br
capri
The Following User Says Thank You to capri For This Useful Post:
Old 01-30-2007, 10:56   #12 (permalink)
sulai2k's Avatar
Member: 311025
Sonork: 100.1607375
Thanks Meter: 171
2310 not charching
2310 not charching
first u check short
light short show
then u try this solution
100% ok
any thanks pls mail [email protected]
The Following 2 Users Say Thank You to sulai2k For This Useful Post:
Old 01-30-2007, 11:04   #13 (permalink)
Member: 144946
Thanks Meter: 4
only one solution C H A N G E THE U E M ic
The Following User Says Thank You to san7man For This Useful Post:
Old 01-30-2007, 11:17   #14 (permalink)
Crazy Poster
Member: 201598
Thanks Meter: 3
Definitely The Problem Is Uem
The Following User Says Thank You to franzGSM For This Useful Post:
Old 01-30-2007, 11:19   #15 (permalink)
capri's Avatar
Member: 396326
Thanks Meter: 229
@zafhal remove the components mention by sulai2k it works 100%... good luck.
thanks sulai2k.. Do you have schematic 2301 could u give that or e-mail me... or link me.
thanks again...
br
capri
2310 not charging plz helpe me arent kashig Nokia Hardware & Hardware Repair 4 11-16-2009 12:10
2310 Not Charging FDie Nokia Digital Core Technology 4 ( DCT-4 ) 1 05-22-2009 13:12
need help nokia 2310 not charging fzlmn Nokia Hardware & Hardware Repair 6 06-02-2008 11:51
nokia 2310 not charging fzlmn Nokia Digital Core Technology 4 ( DCT-4 ) 5 04-22-2008 17:21
need help nokia 2310 not charging fzlmn Nokia Hardware & Hardware Repair 3 11-01-2007 14:09
Page generated in 0.30454 seconds with 10 queries
