2600 contact service hi everyone i have nokia 2600 contact service i tried to flash it but it didnt response then i gave a little heat on uem then make it flashed it flash on mt-box but gave me an error erasing PPM file like below.... MTBOX: 00212c9355 - Nokia Flash/Repair v1_32 Box: CR V 1.002 256 Code: NK V 1.001 1046 SN: 00212c9355 Nokia Unlimited: 364 times started SonyEricsson Trial: 0 left, each max 15min Using Tx2 Data line. Processing File: rh59_06.420 Boot... ASIC ID: 2201 DCT4 u_2nd.fia u_amd.fia Configuration Info (9F): Number of Flashes: 2 01000000: Amd, 0001 2A7E 0024 0111, 10 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 %%%%%%%% ERROR BOOTING: Using Tx2 Data line. Processing File: rh59_06.420 Boot... ASIC ID: 2201 DCT4 u_2nd.fia u_amd.fia 84CA6E77D13811257B097C7B63AF Configuration Info (9F): Number of Flashes: 2 01000000: Amd, 0001 2A7E 0024 0111, 10 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[4.44 MB]... request erase [01000000 to 0100FFFF] request erase [01010000 to 013AFFFF] request erase [013B0000 to 013EFFFF] request erase [017B0000 to 017EFFFF] request erase [01FB0000 to 01FEFFFF] Waiting response for 300 Sec...in 20.45s Flash[1.70 MB]...in 5.77s * * Processed file in 34.72 seconds Processing File: rh590_nai6.42mb_2 Low level format...OK Boot... ASIC ID: 2201 DCT4 u_2nd.fia u_amd.fia 84CD299401D0F06AE15260E5AEA0 Configuration Info (9F): Number of Flashes: 2 01000000: Amd, 0001 2A7E 0024 0111, 10 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[0.25 MB]... erasing region [01370000 to 013AFFFF] in 1.88s Flash[0.18 MB]...in 0.81s * * Processed file in 18.45 seconds Extract content...OK Processing File: rh59_06.42mb Boot... ASIC ID: 2201 DCT4 u_2nd.fia u_amd.fia Configuration Info (9F): Number of Flashes: 2 01000000: Amd, 0001 2A7E 0024 0111, 10 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 %%%%%%%% ERROR BOOTING: Using Tx2 Data line. Processing File: rh59_06.420 Boot... FAILED TO BOOT PHONE!!! Make sure that phone is connected. Using Tx2 Data line. Processing File: rh59_06.420 Boot... ASIC ID: 2201 DCT4 u_2nd.fia u_amd.fia 84CA6E77D13811257B097C7B63AF Configuration Info (9F): Number of Flashes: 2 01000000: Amd, 0001 2A7E 0024 0111, 10 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[4.44 MB]... request erase [01000000 to 0100FFFF] request erase [01010000 to 013AFFFF] request erase [013B0000 to 013EFFFF] request erase [017B0000 to 017EFFFF] request erase [01FB0000 to 01FEFFFF] Waiting response for 300 Sec...in 20.45s Flash[1.70 MB]...in 5.45s * * Processed file in 34.44 seconds Processing File: rh590_nai6.42mb_2 Low level format...OK Boot... ASIC ID: 2201 DCT4 u_2nd.fia u_amd.fia 84CD299401D0F06AE15260E5AEA0 Configuration Info (9F): Number of Flashes: 2 01000000: Amd, 0001 2A7E 0024 0111, 10 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[0.25 MB]... erasing region [01370000 to 013AFFFF] in 1.88s Flash[0.18 MB]...in 0.81s * * Processed file in 18.14 seconds Extract content...OK Processing File: rh59_06.42mb Boot... ASIC ID: 2201 DCT4 u_2nd.fia u_amd.fia Configuration Info (9F): Number of Flashes: 2 01000000: Amd, 0001 2A7E 0024 0111, 10 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 %%%%%%%% ERROR BOOTING: REGARDS MAIMOON MOBILES |
hi bro, now you have to reball uem ic and then flash best of luck jimmy |
yes uem rebal only.................;) ..::Mr Fone::.. |
try to unlock it with universal or wash the board totally... |
Brother first flash first file and then flash 2nd file and then flash third file your problem solve 100% i solve problem already........................ |
Erase and full flash it with latest flash file.And write PM file.If still its UEM fault. |
after flesh nokia 2600c contect service please give me solution |
