2600 insert sim one nokia 2600 show insert sim card how to solve that problem |
Check Sim Filter. GreetZ |
B.R ROBISH |
2600 insert sim thnks it working 100% |
remove the SIM driver IC and make jumper/short using some small wire. its easy to do ;) |
hi CHEAK BATTRY CONNECTER SOMETIME'S IT COUS INSERT SIM CARD.... WBR MUNNA +919810626677 e-mail- [email protected] www.gsmmunna.com |
its is jumper of sim IC same as 8310? |
Yes... u can use same jumper trick as 8310. |
yes u should make the jumper it is the same................ |
you must work on your sim chambers, sometime clean your sim card again before insection. this is a common trick. check your sim chamber very well, i will post you more developing. bestman |
ins sim ways 1 Attachment(s) 2600 ins sim card this jums helps u good luck |
urgent! urgent!! urgent!!! 2600 - network comes within 3 secs then disappears may I get some solutions....... epotron |
2600 dead hi mine has a different problem , it does not switch on after being droped so i cleaned and re-hoted the pcb and tried to flash with griffin v2.0826 but below is the massege i get ACTIVATED BOX using autopower Initializing Phone...Send 2nd loader failed, probable cause: *Too slow PC *Noise environment *Too long cable *Bad luck Error[5555B040]. so how can i solve the problem ???????? |
yellowcom: check the batt pins, im sure they have a short soldier, re soldier them or put new onees, then u can check the board for any diodes that fell off when dropped, matcht eh board with another working boards and look for missing parts. wbr |
thanx for the solution |
