Old 08-24-2007, 16:19   #1 (permalink)
makkah mobile's Avatar
Member: 226363
Sonork: 03--4899925
Thanks Meter: 569
6230 with charging going hot ... :) any solution???
hi room there is one 6230 when i connect the charger after 5 mints going hot and battery not going to charge... any solution ???
Old 08-24-2007, 16:32   #2 (permalink)
meo786pk's Avatar
Member: 465162
Thanks Meter: 683
Dear brother, see it may be usefull for you
Old 08-24-2007, 16:39   #3 (permalink)
Member: 282073
Thanks Meter: 13
screw off the phone...n try to charge it again...then sense it with ur finger to see which ic is getting hot then change it...mostly it will b the power ic..good luck...
Old 08-24-2007, 17:28   #4 (permalink)
Member: 226363
Sonork: 03--4899925
Thanks Meter: 569
i have solved this problem by change this area
i have solved this problem by change this C121 and V101 coz board is not short. thanks
lgkg290 charging problem help me any solution shani72 LG Hardware Repair 0 06-08-2009 06:06
6230 with charging going hot ... :) any solution??? makkah mobile Nokia Hardware & Hardware Repair 0 08-24-2007 15:47
6230 only charging will not go on benie Nokia Hardware & Hardware Repair 6 04-01-2005 21:24
8210 with batery discharge very quickly, any solution ? Kilowat Nokia Hardware & Hardware Repair 4 03-22-2002 14:49
Page generated in 0.27946 seconds with 10 queries
