2626 flashing error nokia 2626 flashing ok but does not power on any soloution |
FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\Rm-291\rm291__06.80.mcusw PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\Rm-291\rm291__06.80.mcusw PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\Rm-291\rm291__06.80.ppm_ej CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Russian,Ukrainian Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\Rm-291\rm291__06.80.mcusw PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\Rm-291\rm291__06.80.ppm_ej CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\Rm-291\rm291__06.80.image_ej ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Russian,Ukrainian Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... MCU: C:\Program Files\Nokia\Phoenix\Products\Rm-291\rm291__06.80.mcusw Booting phone... MCU ID: 0x3040 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0xE822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: c5 Loader is ready... P-key nokia module version 01.02 MSID: 847770E1A86CFE03922406D50C MSID decoded: 4F16BAE900418D04A8000000 FAID: 8CC4518175D3E11D094DF67B Operation took 0 minutes 12 seconds... Erasing... Found 3 interval(s) to erase Erasing area: 01000000 - 0101FFFF... Erasing area: 01020000 - 018DFFFF... Erasing area: 01EE0000 - 01FDFFFF... Operation took 1 minutes 8 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 53 seconds... Restarting MCU... CNT: C:\Program Files\Nokia\Phoenix\Products\Rm-291\rm291__06.80.image_ej Booting phone... MCU ID: 0x3040 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0xE822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: c5 Loader is ready... P-key nokia module version 01.02 MSID: 84B2CA0138B81D82BE610902F9 MSID decoded: D26EBAF100418D04AA000610 FAID: FD28E85605D507B77D983F6F Operation took 0 minutes 11 seconds... Erasing Content Pack... Found 1 interval(s) to erase Erasing area: 01B80000 - 01EDFFFF... Operation took 0 minutes 23 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 11 seconds... Restarting MCU... Operation took 0 minutes 1 seconds... Extracting Content Pack... Error setting local mode... CP Extract Failed! PPM: C:\Program Files\Nokia\Phoenix\Products\Rm-291\rm291__06.80.ppm_ej Booting phone... MCU ID: 0x3040 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0xE822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: 25 Loader is ready... P-key nokia module version 01.02 MSID: 84918C2A610D215B4C7E848D9C MSID decoded: 3E4EBAE900418D04A8000000 FAID: 7043F2E6781DB1BA24469881 Operation took 0 minutes 11 seconds... Erasing PPM... Found 1 interval(s) to erase Erasing area: 018E0000 - 01B7FFFF... Operation took 0 minutes 18 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 10 seconds... Restarting MCU... Flashing Done! Operation took 4 minutes 37 seconds... After flash processing... Waiting for phone to boot... Failed! Aborting! |
mxkey log.......... ASIC ID: 0x3040 [UPP_4M ver: 4.1] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH - COMBO FLASH ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0084A272:DA3BDA66 ASIC type: 11 UEM Imei: *************** Flash Imei: Empty Invalid imei checksum ! Processing MCU file: rm291__06.81.mcusw [DCT4,DCT4 ALGORITHM] size: 8.60 MB Supported Ids: 3040 ASIC ID: 0x3040 [UPP_4M ver: 4.1] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: FFFF FFFF [unused/removed] ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0084A272:4E99DA60 Area [01000000-0101FFFF] erased in 0.141 s Flash programming ... Error while programming [14] at 0x01000000, Result: 0072 flashing terminated ! Task failed at (08000025)!!! Last RX buffer: 00 72 |
Bro use mx key 10000% solution |
salam, 1. please rehot ic flash and UEM 2. full erase 3. write mcu+ppm+cnt 4.wite pm 5.unlock 6.full factory setting 7. enjoy! |
1. full erase 2. full flash if set ok write pm and unlock and full factry 3. if not solve clean pcb and try again flash if not solve 4. remove local mode test mode register 5. if not solve rehot flash and uem |
