..::2626 hang problem::.. nokia 2626 hang problem, both with sim and without sim, sometime hang on startup ,sometime complete power on and than no keypad working, when i put headset and power on the set than for a while it works fine, plz help? |
no one have solution or suggestion. |
such a big forum and no one here to reply. |
I too have 1 2626 with same problem set restarts and hangs after 5-10 seconds on startup, flashed it with latest firmware with ufs,jaf and also with mtbox.......... still the problem is same |
Dear brother, Please flashed it with latest files. Muhammad Afzal Meo Quote:
already flash with latest files ,still same ,i think its hardware, anyone solved this by hardware, plz share? |
"Hum" you can change the headset jack your phone will ok its 100% working and tested |
u tested in which fault? |
hi, hit um and flaser.then flash it again......good luck.... |
Dear brother, re-hot the uem then Flashed it and post the results. Muhammad Afzal Meo Quote:
Rehot Flash And Uem Other Wise Reball It.....post Result...:) |
2626 Hang Problem Soulution hello my Dear Bro.. This is a tipicalt fault but try to this soulution1- Swap Upp and around near cpacitor Format File System From Jaf and Erase Fls From Jaf and than Flash again with version of 4.61 and than write pm file and unlock phone and than write full factory setting Now chack your phone will be ok 100% Soulution Important note : 2626 is a Series 40 Phone It has a file System File-2 Format you phone file system. Insh***** Phone will be ok |
u people sure that this is uem and flash problem not upp? |
yes br 100% uem problem rebal and then flash it i hope it will b work if not solved change uem only ..................;) ..::Mr Fone::.. |
