03-25-2009, 10:15 | #1 (permalink) |
No Life Poster Join Date: May 2008
Member: 774169 Status: Offline Thanks Meter: 123 | 2626 ok without charger hangs , run ok with charger i have 2626 which hangs without charger but with charger the handset is running perfect. i flashed washed and cleaned pcb . so i request experts to help me out of this. regards [email protected] |
The Following User Says Thank You to mukeshdurg For This Useful Post: |
03-25-2009, 11:03 | #4 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | first search forum before post , solution already posted many times , anyway if same after putting diod change upp I think your problem will be solved then |
2610 hang but ok with charger | ashraf_bcs | Nokia Hardware & Hardware Repair | 6 | 09-05-2010 14:45 |
6233 works fine with charger but without charger turns off | dapinderjit | Nokia Hardware & Hardware Repair | 17 | 03-29-2010 11:20 |
my v_56 auto off with out charger with charger set work ok | shani72 | Sagem Hardware Repair Area | 1 | 05-24-2009 08:13 |
nokia 2626 hang..full flash ok,but still hang. | rafcell | Nokia Hardware & Hardware Repair | 5 | 12-20-2008 13:04 |
5140i NOT charging without charger, works good with Charger :-) | dazexy | Nokia Hardware & Hardware Repair | 0 | 10-23-2007 12:04 |
