Old 03-24-2010, 13:46   #1 (permalink)
Member: 572872
Thanks Meter: 21
2626 strange problem
Respected Seniors,
I have got a 2626 in dead condion in HWK it takes Flashing, UI Setting ,shows info & Local mode in sw but with battery can not ON .
Can any body guide me as it shows impedance also on ON OFF.
Old 03-24-2010, 13:55   #2 (permalink)
marvin03's Avatar
Member: 1015389
Sonork: 19830303
Thanks Meter: 524
Originally Posted by pavankhatri4024 View Post
Respected Seniors,
if you put charger on it what happen?
if phone charging.. look for switch way...
Old 03-24-2010, 13:58   #3 (permalink)
.:gsmXpert:.'s Avatar
Member: 471816
Sonork: 100.1623472
Thanks Meter: 57
Old 03-24-2010, 14:00   #4 (permalink)
klmamn's Avatar
Member: 986273
Thanks Meter: 397
Originally Posted by amjad4u2 View Post
sorry but he wants 2626 solution not 2630or2600c
The Following 2 Users Say Thank You to klmamn For This Useful Post:
Old 03-24-2010, 14:14   #5 (permalink)
suraj9860607689's Avatar
Member: 787710
Sonork: not using
Thanks Meter: 766
bro chk ur sluton..........................
Old 03-24-2010, 14:19   #6 (permalink)
Member: 787710
Sonork: not using
Thanks Meter: 766
[IMG][/IMG]
...:::SuraJ:::...
The Following User Says Thank You to suraj9860607689 For This Useful Post:
Old 03-24-2010, 14:55   #7 (permalink)
ABUU YUUNUS's Avatar
Member: 319112
Thanks Meter: 163
respected seniors,
i have got a 2626 in dead condion in hwk it takes flashing, ui setting ,shows info & local mode in sw but with battery can not on .
Can any body guide me as it shows impedance also on on off.
you may get such a condition if the pcb is liquid damaged. In this case, you need a thorough cleaning of the pcb with nutrocellulose thinner as much as you can. Clean well until there are no more signs of verdigris (whitish substance) on the pcb. If this can not solve the problem, you need to check the bsi line. If this is open you need to close the circuit. In the same vein, check to see that all the power tracks are okay.
Old 03-24-2010, 15:55   #8 (permalink)
Member: 387116
Sonork: 100.1650000
Thanks Meter: 175
first chake power key valeo if ok then clean or change pcb
Old 03-24-2010, 17:08   #9 (permalink)
Member: 1241659
Thanks Meter: 161
change battery connector and check BSI line
Old 04-29-2011, 10:03   #10 (permalink)
octopus_mobile's Avatar
Member: 1294102
Sonork: 100.1655641
Thanks Meter: 79
Thumbs up 2626 power key ways........
Originally Posted by suraj9860607689 View Post
[img][/img]
...:::suraj:::...
nice sharing mr suraj..........!!!
n95 (rm-159) strang problem Tayyab_raja777 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 04-21-2010 09:01
I8510 strang problem naslejavan QUALCOMM Models (3G) 4 03-30-2010 09:32
n95 (rm-159) strang problem Tayyab_raja777 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 03-29-2010 14:45
Nokia 2626 Strange Problem yeerk05 Nokia Hardware & Hardware Repair 3 04-21-2009 09:59
Nokia 2626 strange problem raghav1212kumbh Nokia Hardware & Hardware Repair 0 04-14-2009 06:42
Page generated in 0.17263 seconds with 9 queries
