2650 flashing oK but not Powering ON Version 6.01 Flashing OK but can't power on nor charge. What can be the problem. |
flash with update files without display, after flash info |
erase then flash and put charger in charging socket while flasing and do not select cnt |
After flashing check ui setting if ok then change lcd if not then resold upp and uem with low temprature all will be ok |
2650 not powering on just got one, i check with jaf and its ok. Also charging very good. but can not power on. I'll try and post result tomorrow. |
check the switch, if the phone is charging??? update your phone with the latest version of the software. |
I flashed it with new version ( 2650 - RH-53_dp_v_60.0_mcusw06.06). The phone switches OK and works fine. After i gave it to my customer yesterday he then brought it back today not powering. Then I notice the back battery cover has an effect when closed. I change the body an everything OK ( for now). I made two conclusing is: 1- It was software. After flashing it works. Later the customer maybe he drop the phone For the cover to have problem. 2- maybe all along was the cover. But if it was the cover i believe i would have seen it before i assure u. So this thread solution is 1. Thanks techseeker"ems". |
