11-25-2005, 09:26 | #2 (permalink) |
No Life Poster Join Date: Dec 2001 Location: United Arab Emirates, Dubai Age: 52
Member: 7751 Status: Offline Thanks Meter: 74 | @GSM_HACKING2003 Does it boot first of all ? Do you get light in all 5 LED's on the main board ? or only the 2 top LED's ? I had a similar one some time back with excat same fault, only the 2 top LED's were lighting up, the other 3 small LED's did not.... UPP change solved the problem (Be aware it glued) Regards Last edited by GSM Coolhawk; 11-25-2005 at 09:59. |
12-07-2005, 23:49 | #5 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Shenzhen China Age: 68
Member: 16350 Status: Offline Sonork: 110823 Thanks Meter: 42 | I also have this problem. After changing the flex and lcd(as the original was broken) phones works when i start, but when i close the flip(one side over the other) light come on the screen but it rest blue. I have full flashed the phone but it does same things... |
05-28-2006, 17:12 | #11 (permalink) | |
Freak Poster Join Date: May 2002 Location: right here Age: 58
Member: 11977 Status: Offline Thanks Meter: 1 | Quote:
05-29-2006, 17:02 | #12 (permalink) | |
Junior Member Join Date: Mar 2006
Member: 253110 Status: Offline Thanks Meter: 3 | Quote:
06-02-2006, 11:09 | #14 (permalink) |
Freak Poster Join Date: Dec 2004 Age: 47
Member: 101007 Status: Offline Thanks Meter: 27 | first check wat lcd u r using 7210 lcds normally wont work for 2650 remember.. does the flx cable work properly.. flash the phone wit latest version if you wan to use 7210 lcds sometimes it work wit some phone.. i've tried b4.. but better use 2650lcds it self |
07-16-2006, 05:36 | #15 (permalink) | |
No Life Poster Join Date: Mar 2002 Location: khonkean,thailand
Member: 10084 Status: Offline Thanks Meter: 283 | Quote:
BR | |
Motorola L6 with Blue LCD | pepik | Motorola Hardware Repair | 27 | 05-15-2009 17:46 |
6100 lcd blue new lcd no display some blue lcd | canliyayin | Nokia Hardware & Hardware Repair | 12 | 01-09-2009 09:04 |
T610 with blue lcd | etgo | Sony Ericsson Hardware Repair | 3 | 03-07-2006 12:09 |
Help With Sl55 Blue Lcd | The Repair Shop | Siemens Hardware Repair Area | 1 | 12-31-2004 12:51 |
SL55 with blue lcd | Voytaz | E-Gold Based Phones | 4 | 09-18-2004 09:57 |
