01-24-2006, 16:06 | #1 (permalink) |
Insane Poster Join Date: May 2004 Location: nigeria Age: 43
Member: 65960 Status: Offline Thanks Meter: 0 | 2100 C/s |
01-27-2006, 07:49 | #3 (permalink) |
Junior Member Join Date: Dec 2004 Age: 52
Member: 95562 Status: Offline Thanks Meter: 0 | 2100 contact service Use geo flasher.cable same as rollis flasher 1)write eeprom 2)write mcu+ppm.phone still says contact service 3)use 3rd button on b-phreaks (phone must be on).it will read and the it will give an error 4)take out battery and put back.switch on phone and u will see insert card 5)open locks with b-phreaks 6)open rolis tool ,read phone,click change imei,sfr,udate faid done.works 10000000000%.tested be myself more than 40 phones |
02-25-2006, 10:57 | #4 (permalink) |
Junior Member Join Date: Oct 2005
Member: 189289 Status: Offline Thanks Meter: 1 | Erase Flash,Select MCU,PPM and PMM, Flash the Set, Appliy UI Options, Rebuild Imei, Apply UI Options, May be there is no Menu, Select another PPM and flash "PPM Only", Full Factory Default 1000000000000000% proved Formula |
2100 short circuit need 2100 diagram | erkan06us | Nokia Hardware & Hardware Repair | 8 | 05-13-2006 09:14 |
SGH-2100 Contact provider | D-Brain | Samsung Hardware Repair | 2 | 01-19-2002 14:24 |
samsung 2100 after 20sec call end | tone | Samsung Hardware Repair | 2 | 12-16-2001 13:04 |
unlockclips for panasonic and samsung 2100+2400 | aj1rtd | Main Sales Section | 0 | 09-06-2001 00:15 |
Samsung sgh-2100 | Pandemonio100 | Samsung Hardware Repair | 2 | 09-04-2001 18:59 |
