2680s works only with charger..please help.. greetings to all of you..is there by any chance that anyone here has encountered this kind of problem? i have a Nokia 2680s and my problem is that it only works well if there is a charger connected to it..if i remove the charger the phone would hang and then shut down...if you have encountered this kind of problem..please kindly share the solution that you have..thank you and more power to all of us |
up up up................................. |
bro try to reflash the phone if not ok tray reheat power IC or charging IC |
This is UPP problem. |
brother do this steps change battery , if not work change battery conecter, if not work change cpu ur problm will 100% solved |
This is UPP (CPU) problem 100%. No need change connector or reheat phone. You need change UPP only. |
here's the solution... http://img203.imageshack.us/img203/7...utoshutoff.jpg |
HI sir change things why means hardware connection.:eek::eek::eek::eek: 2680s works only with charger..please help.. brother do this steps change battery , if not work change battery conecter, if not work change cpu ur problm will 100% solved regards, phe9oxis, Guidebuddha :homework help online tutor from india- |
The new Nokia X5-01 is fully optimized for music and messaging!! Check out the full specs and features here Device Details -- Nokia X5-01 |
Your Very welcome Bro... |
Can you Make This in Other Section sir....?? |
thanks very much works very well |
