Old 11-29-2010, 08:40   #1 (permalink)
Member: 1453066
Thanks Meter: 75
1600 back light not off always on
change light ic and other component but same plz help
The Following User Says Thank You to gsmhuda For This Useful Post:
Old 11-29-2010, 08:51   #2 (permalink)
msattar123's Avatar
Member: 645436
Thanks Meter: 1,501
try this only
Uploaded with ImageShack.us
The Following User Says Thank You to msattar123 For This Useful Post:
Old 11-29-2010, 08:52   #3 (permalink)
Member: 1434798
Thanks Meter: 3
maybe keypad ic short
Old 11-29-2010, 09:02   #4 (permalink)
Member: 959010
Sonork: 100.1602440
Thanks Meter: 445
I think u r nokia phd holder...
Old 11-29-2010, 09:06   #5 (permalink)
Member: 902109
Sonork: mic™
Thanks Meter: 16
did you try o flash the phone sir?
if no , try to flash in high version
Old 11-29-2010, 09:34   #6 (permalink)
Member: 1453066
Thanks Meter: 75
Originally Posted by msattar123 View Post
try this only
change but not solve plz onather
Old 11-29-2010, 10:05   #7 (permalink)
/\/\A/\/|'s Avatar
Member: 900083
Thanks Meter: 601
dear that is 100% solution i done many phones with this component if your problem is same after change this so please check in your phone setting display setting back light time (you should be select normal)
Old 11-29-2010, 11:21   #8 (permalink)
m.awais.as's Avatar
Member: 1284347
Sonork: 100.1592292
Thanks Meter: 977
Change light ic & coil
i think shortage for this
section
Old 11-29-2010, 11:22   #9 (permalink)
msattar123's Avatar
Member: 645436
Thanks Meter: 1,501
Wink
sir g uem problam................................
Old 11-29-2010, 11:33   #10 (permalink)
Member: 1434798
Thanks Meter: 3
Wink
oh i m sorry sir
but i had same problem after keypad ic changed
may b i was mistake
i did knew that u are phd holder of nokia
Old 12-22-2010, 13:31   #11 (permalink)
Member: 1345042
same proble plz try another solution sir
Old 12-22-2010, 15:58   #12 (permalink)
jadusumon's Avatar
Member: 1251770
Thanks Meter: 142
brother , try this if not o k remove all light component & make jumper ....
[email protected]
bangladesh
The Following User Says Thank You to jadusumon For This Useful Post:
Old 02-19-2011, 18:58   #13 (permalink)
Member: 1228041
Thanks Meter: 11
hi bro 1600 display is come few second it come blu lcd help me
Old 02-19-2011, 22:23   #14 (permalink)
Member: 663147
Thanks Meter: 7
replace three leg ic ........
Old 02-20-2011, 05:48   #15 (permalink)
krishnadas.g's Avatar
Member: 836786
Sonork: 1,009 horrold
Thanks Meter: 48
i think the ennabling path is short bet ween transistor and uem,... so chance to uem.............
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
For Jefferson -6110 goes off itself sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-19-1999 21:28
Page generated in 0.22588 seconds with 9 queries
