06-12-2011, 03:02 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | ..::2690 camera replacement tips and tricks::.. for removing faulty cam give heat from under side of pcb now main thing how to fix other cam here is 2690 cam Uploaded with ImageShack.us |
The Following 3 Users Say Thank You to HUM For This Useful Post: |
06-12-2011, 03:03 | #4 (permalink) |
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | the main reason to remove this cover is? bcoz of this cover cam ball have no contact with pcb after removing the cover u can easily make balls thicker with the help of iron finally put cam on pcb and again give heat from underside and hopefully u get 100% result tested by me Uploaded with ImageShack.us |
The Following 2 Users Say Thank You to HUM For This Useful Post: |
04-03-2012, 19:00 | #10 (permalink) |
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | besides this procedure if anyone have more easiest way to fix camera please share here |
The Following User Says Thank You to HUM For This Useful Post: |
04-04-2012, 14:05 | #13 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Nepal
Member: 1061924 Status: Offline Sonork: 100.1612111 Thanks Meter: 95 | i dont think this is the safe idea, well it needs perfect experience to replace camera...anyone knowing the better & safe idea plz post here,,,, |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
