2700 restart problem i have one 2700 restart problem i have flashed the handset with latest flash file but the problem is same can any one help me |
Hello sir u check bsi voltage |
2700 restarting replyse blutooth ic .................................................. ..................... |
Brother, May be water locked, just clean it and specifically have a look at Blutooth IC area , clean this area and rehot . it may be worked out. If your mobile able to read the mobile info part completely then it will be hardware problem 100%. |
repair sd man.by mx key.i repair many time by mx key..do it tested by me |
ha ha ha ha ha........................ its not same case boys try frist and try to post your successfuly expreriance Logs,,,,,, I did sooooo |
at fast you do job,after give your answer........]pls change the keypad ic mb 80%%%%%%%%ok............ |
