2700c with memory restart i receive 1 nokia 27000c set.without memory ok and with memory restart .so i try to flash but give this error.now it is dead pls help http://img534.imageshack.us/img534/7372/2700ch.jpg |
Use GPG Cable to Flash ;) |
i used 7 pin universal cable.but problem same |
flash with usb cable 4 retart change mmc ic |
w8.i will replay after ur work.thanks for replay |
these r fbus log did u try usb flashing?????????????? |
thanks for help.with ur process i do 1.remove camera 2.remove mmc ic 3.use usb to flash now set is alive |
i don't undestand what's the fault?????????? now set again restart itself???????? |
if in both condition set restart remove bluetooth ic 100% WORKING today i done one 2700c br, vijay-gsm |
without memory set restart dear |
i said that if in both condition{with memory or without memory} set restart then remove bt ic IF RSET RESTART ONLY WHEN MEMORY INSERTED THEN MMC PROBLEM or if u think u r smart :mad::mad: I KNOW BT REMOVING WILL HELP U IF WORK ONLY CLICK ON THANKS BUTTON:D:D |
