04-14-2012, 07:36 | #1 (permalink) |
No Life Poster Join Date: Feb 2012 Location: kanpur
Member: 1722956 Status: Offline Sonork: mybestfriend.adeel Thanks Meter: 305 | nokia n72 white display i remove boot ic and make jumper but same as. x-pert help me fast plz. |
04-14-2012, 07:46 | #2 (permalink) |
No Life Poster Join Date: Mar 2009 Location: Basti, I N D I A Age: 34
Member: 988641 Status: Offline Sonork: sanjay chaudhary Thanks Meter: 342 | if jumper is correct then rehot or change retu ic............. |
The Following User Says Thank You to s.s.s.s. For This Useful Post: |
04-14-2012, 08:32 | #4 (permalink) |
Member: 1722956 Status: Offline Sonork: mybestfriend.adeel Thanks Meter: 305 | i falsh but- Booting Phone via FBUS... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done AdvanceBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME STARTS HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded after 3 Attempts SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 12 (0x0C) 1 SYSTEM_ASIC_ID 01 Block Length : 5 (05) BB ASIC Index : 1 (01) APE ID DWORD 0 : 17100701 2 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 1 (01) APE Mode Id : 00 3 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 1 (01) APE ID DWORD 0 : 5C5662DB ID DWORD 1 : 87C8D582 ID DWORD 2 : A7CD666D ID DWORD 3 : F48B16E6 ID DWORD 4 : F12F82CD 4 ROOT_KEY_HASH 14 Block Length : 21 (15) BB ASIC Index : 1 (01) APE Hash : 2C 05 36 9F 57 CC 3C 4C F9 E7 83 E8 3D 9B 51 2B 00 00 00 00 5 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 1 (01) APE CRC 0 : AB5E4ADB CRC 1 : 27A06946 6 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 000C1921 ID DWORD 4 : 01012200 7 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 8 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000353 9 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 1DE0010D ID DWORD 1 : B2B54951 ID DWORD 2 : E05D5964 ID DWORD 3 : 77357360 ID DWORD 4 : 386A83A1 10 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 11 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : E9 EF F4 BF AA 53 93 21 7C A6 B1 77 55 FC 3E 14 12 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : F28A211F CRC 1 : CEA7B19D Checksum C2 SearchForBootstrap_DCT5.. C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\RAP3Gv2_2nd.fg Boot File - Version 01.021.00 Boot File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForBootstrap_DCT5 : No Error - 0 (0x00) Secondary Loader Sent... ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 03 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0001 -> Device ID : 0033 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0121 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : FFFFFFFFFFFFFFFFFFFF 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 5A SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Searching Algorithm Files NOR (00) ManID :0001 DevID :0033 ExtID :0000 RevID :0121 Flash Descriptor Manufacturer Code : 0001 Device ID : 0033 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 00800000 (8 MB) VPP Info : 0009 Erase10s : 0F Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\RAP3Gv3_algo.fg Algorithm File - Version 01.040.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request No PAPUBKeysHash Returned Searching for APE Boot File.. SearchForBootstrap_DCT5... C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\helen3_2nd.fg Boot File - Version Boot File - Revision 0x (2) eBB5ProtocolType == New TransmissionTypeRequest_DCT5.. SuggestedType : 04 DDR & 2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDR & 2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) SendAPECodeRequest_DCT5.. SendAPECodeRequest_DCT5 FLS1_NO_ERROR.. ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : 03 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : NAND 01 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0036 -> K5E1212ACM Extended/Fixed ID : 005A Revision ID : 003F 2 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 19 BB ASIC Index : APE 01 Data : OMAP1610 GBBM-1.8.1 ALG 3 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : APE 01 Device Type : NAND 01 Device Index : 00 Device Contents : 00020000000600000000 Checksum : 63 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Searching for APE Algorithm File.. SearchForAlgorithm_DCT5 Flash Descriptor Manufacturer Code : 00EC Device ID : 0036 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 04000000 (64 MB) VPP Info : 0015 Erase10s : 0F Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 VPPInfo : VPP_INFO_3V_MASK VPP_INFO_12V_MASK VPP_INFO_ERASE_MASK C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Old\h3_sam_nand_gbbm.fg Algorithm File - Version 01.033.00 Algorithm File - Revision 0x0000 (0) eBB5ProtocolType == Original TransmissionTypeRequest_DCT5.. SuggestedType : 04 DDR & 2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDR & 2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) SendAPECodeRequest_DCT5.. APE Algorithm Sent SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 01 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 APE PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D ( CMT and APE PAPUBKEYS HASH are Identical ) Scanning Simlock Applet Type... Simlock Type is UNKNOWN... |
