3100 no light in screen and keypad plz help i've 3100 no light in screen and keypad any help please |
change its 1851 8 leg ic akki |
try checking all emitting ligth diode and clean your phone board again. try this now.......... bestman. |
try the other LCD... if same change the 1851 ic and the transformer... if same check the connections (use the multitester) check the continnuity of the connections... |
i have backlight problem on 3100,so please i need viewing on board solution. |
please what are the possible solution all nokia network problem secondly what are the possible solution to N-GAGE and 3650 power problem |
depends on problem... not all signal problems isn`t same... |
i need on board solutn and running of wire for nokia [all] network problem. i need solution to nokia 6108 charging problem |
Wire solution u mean Jumper trick ?? replacing duplexer (antenna switch by wire isnt good repair) otherwise u will lost 1800mhz frequency. When u wanna hint to repair nokea 3310 signal, u must explain ur problem very well. coz there are too many parts in phone which can be damaged, and phone has no signal. (PA, COBBA, DUPLEXER, 1stVCO-crystal, Haggar, Filters...etc. even it can be broken track and so on.) Explain ur problem better. We will try to help you. Nokia 3310 signal problems aren`t same. U can not use only one solution to repair all without signal 3310`s. !!!And jeerich please post nokia network problems to right section . !!! |
i have 3510 i light not working plz help me |
Then follow this link. http://forum.gsmhosting.com/vbb/show...ht=3510i+light USE SEARCH FUNCTION |
hi akshay why the 1851 changed ? in key pad and light fault can u explain it ????? thaks |
ATT. AIRON6 Hi I have same problem on 3 3100's. Iv'e changed the 1851 and transformer but still same problem. The 1851 is same ic which is used on 6600 phones but I cannot find any relationship between the 2 phones. Any other ideas pls?? tonytony |
btw 3100 had no liquid damage before, coil was s/c before replacing (good). Fault must be in backlight trigerring section, that is, a broken track which sends signal to 1851 to switch on b/l. tonytony |
