05-11-2005, 11:46 | #2 (permalink) |
Freak Poster Join Date: Jan 2005
Member: 106049 Status: Offline Thanks Meter: 20 | is your 6630 unlocked also is it maybe barred if not then send it back to your nearest nokia repair centre or pop in to cpw and they will repair it free of charge as it will be under warranty its under a year old |
04-13-2006, 02:02 | #4 (permalink) |
Freak Poster Join Date: Jun 2004 Age: 44
Member: 69633 Status: Offline Thanks Meter: 2 | Same prob here 6630 no network. I tried GSM and Dual band. When I try manual search finds both networks but always NO ACCESS!. I try two diff. sim cards. I change RF ic. Exactly same prob. Any ideas? |
04-13-2006, 12:38 | #6 (permalink) | |
Junior Member Join Date: Apr 2004 Age: 61
Member: 62208 Status: Offline Thanks Meter: 0 | Quote:
second, check ic p.a., ic signal rf and antenna/switch third, if all ok it check if pcboard folded from fall with probable broken tracks under uem quarter, if uem no glued replace uem if not send to nokia b.r. | |
04-16-2006, 10:28 | #7 (permalink) |
No Life Poster Join Date: Jan 2006 Location: jharkhand jamshedpur INDIA Age: 38
Member: 226587 Status: Offline Sonork: 100.1603781 Thanks Meter: 352 | hi all bb5 phone no network is hardware problum this is the cpu u remove n reebol the right cpu |
The Following User Says Thank You to Yuvi For This Useful Post: |
6630 no network ! | asasan | Nokia Hardware & Hardware Repair | 1 | 07-22-2006 05:34 |
Nokia 6630 NO NETWORK | NPL2 | Nokia Hardware & Hardware Repair | 3 | 01-30-2006 17:40 |
6630 no network | samtel | Nokia Base Band 5 ( BB-5 ) | 1 | 11-07-2005 13:48 |
6630 NO NETWORK - help | rjsoo7 | Nokia Hardware & Hardware Repair | 4 | 07-25-2005 18:12 |
nokia 6630 no network | azoz98200 | Nokia Hardware & Hardware Repair | 0 | 03-06-2005 22:59 |
