3100 Power Off After 15 Sec. hi friends.i ve a 3100.when it power on ,its power off after find network 15 sec.i did full erase and write full flash and imei again.the problem didnt solve.i changed the uem and wirte all again.but there s still same problem.i rehoted cpu and flash too.what can i do for solve my problem.could you help me,? |
3100 change uem ............................................ |
chang the power sw I CAN DO THAT |
replace PA and have a nice phone |
rebuit the cpu.flash ic also got effect |
to solve this .. 1st be sure that UEM is good if u dont know chane NEW UEM and write RPL ASC2 2nd change power amplifer (PF) ur problem will solve |
in 3120 after 15 sec.power off so i have taken flash ic, its rebowling the flash ic & attached to 3120 & also with software but problems are second boot error so what can i do solve my problem |
@ erkan06us first you had to check the handset with the new battery. if problem remani the same just change the PF. because when the network receive in the handset after switch on there is maximum power consumption. so plz try with the less risky solution. & also check the battery connector |
i solved my problem.must use new uem,not used.when i use new uem and write rpl my problem was solved.thanks to all. |
change uem write imei good work |
try to replace UEM ic and PA ic may be can solve u'r problem. have a nice day |
thanxxxxxxto all 4 goodwork |
change the uem then same time off or enter the sim off change the pa |
