..::3100 signal fall down when display light off::.. i have 3100 , when i recieve this set ,the parts near pa is missing, i put these parts and signal is ok, but after one day it cant pick a call, when i make a call, furthur i make jumper in place of antina switch....after that it comes to its previous position, signal show for a seconds, i change PA, meljoiner, antina switch, upp, filter....plz help, also rehot uem? its urgent. |
reball UEM ,tested in many set |
when i power on the set it shows signal and than goes down? |
Come On Xpertz Really Need Ur Help? |
change uem with new one. Br. |
It's Not A Uem Problem, On S/w Side Firstly Flash With A Good Pm & Then Check Your Tx Line Clearly Bcos This Fault Is Related To Only Tx Section Jumpering Ant Sw In 6610 & 3100 Is Not An Intelligent Task Bcos In Tx Line Both Handsets Have A Filter Inductor Coil So Making It Jumpered Will Cause The Signal To Be Grounded So Beware About That |
Dont Make Direct Jumper Put Ok Antena Switch. Second Step Is Use Working Mjoiner. Third Step Is Uem. |
i reball uem, change meljoiner, change filters, change pa all conponents taken from ok set, still cant found the solution, already write full pm? |
very very interesting , no one can reply! |
just erase & downgrade to versi 6.01 |
Then Only Way Is To Change Uem. |
mostly problem pf or heger ics check 2 parts not solve only uem......... ;) ..::Mr Fone::.. |
