Old 06-30-2004, 20:38   #1 (permalink)
Member: 16938
Thanks Meter: 28
Speaker N620...
sometime speaker not functions.(voice fail)
WHY????????
Old 06-30-2004, 20:43   #2 (permalink)
bestman's Avatar
Member: 61294
Thanks Meter: 49
tool:
N620 phone.
application:
1.dismantle phone.
2. speaker laying position, if speaker pins are broken.
solution:
solder and couple back properly.
bestman.
Old 06-30-2004, 20:59   #3 (permalink)
Member: 16938
Thanks Meter: 28
clear connectors,chek speaker -100%
problem is more serios!!!
Old 07-01-2004, 04:43   #4 (permalink)
Super Moderator
acyl2000's Avatar
Member: 1922
Sonork: 100.64645
Thanks Meter: 692
1st try check v503..
Old 07-01-2004, 10:02   #5 (permalink)
Member: 16938
Thanks Meter: 28
allready checked All chip varistors V503/506/606......
(remuved)
Nothing!!!!
Old 07-09-2004, 00:18   #6 (permalink)
AlgMUR's Avatar
Member: 72109
Thanks Meter: 22
friend
kosmonaft
i can not understand your problem , explan it a gain i will poste solution here
**Warning**
If you cant understand "speaker not function" then please do not post, and how can you post solution when you dont know the problem at all then ?
Old 07-09-2004, 06:48   #7 (permalink)
Member: 16938
Thanks Meter: 28
prob.- some time speaker not functions, but key beep\tones allways preasent!
clear connetins - not worked
remuve chip varisnors - not worked
change CPU main - not worked
change SW(flashed) - still testing - may be /////// - at preasent day worked///// - but it's not logic.....???
Old 04-11-2009, 16:06   #8 (permalink)
astana2007's Avatar
Member: 285345
Thanks Meter: 324
here is tested solution........................
N620 no speaker classic mobiles Samsung Hardware Repair 2 10-15-2005 06:14
S 300 sim waysss & N620 E speaker maximi2000 Samsung Hardware Repair 0 09-18-2005 17:02
T616(Same as T610) Speaker works but Mic and when in a call speaker doesnt work. Mendes Sony Ericsson 3 04-05-2005 12:30
sl42 no speaker and is not the speaker DREAMGSM Siemens Hardware Repair Area 0 09-08-2003 16:24
N620 - Troubles with speaker-(( kostin VLSI, Conexant, Skyworks and Old Models 4 06-12-2003 16:58
Page generated in 0.18283 seconds with 10 queries
