04-18-2011, 10:11 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Pakistan
Member: 277937 Status: Offline Thanks Meter: 48 | 3110 always security tes fail SW Version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35685202354984-7 Product Code: 0514950 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 356852023549847 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Scanning local SX4 Card ... No SX4 Card found. SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.6 Authenticating using [MX] security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 119.154.74.1 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.6 Authenticating using [MX] security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 119.154.74.1 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request |
The Following User Says Thank You to danishshah For This Useful Post: |
04-18-2011, 10:15 | #2 (permalink) |
Member: 277937 Status: Offline Thanks Meter: 48 | write without nps rpl,write pm 1,309 via pmm autho but no result any idia here is log self test Phone Type: RM-237 SW version: V 07.30 07-05-09 RM-237 (c) Nokia. ID Test name Startup Result 3 EAR_DATA_LOOP Y passed 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 15 SLEEP_X_LOOP Y passed 46 UEM_CBUS_IF Y passed 7 KEYBOARD_STUCK N passed 22 CAMERA_IF N !NOT EXECUTED(03) 20 BACKUP_BATT N !NOT EXECUTED(03) 21 LPRF_IF N !NOT EXECUTED(03) 44 LPRF_AUDIO_LINES N !NOT EXECUTED(03) 2 CURRENT_CONS N !NOT EXECUTED(03) 42 RADIO Y PASSED(00) 69 BACKLIGHT Y PASSED(00) 33 SIM_LOCK N PASSED(00) 93 SECURITY N !FAILED(01) 71 BT_WAKEUP N !NOT EXECUTED(03) 99 IRDA_LED_STRESS N !NOT EXECUTED(03) 96 HOOKINT N !NOT EXECUTED(03) 88 TAHVOINT Y PASSED(00) 56 SLEEPCLK_FREQ N !NOT EXECUTED(03) 101 BTEMP N !NOT EXECUTED(03) 107 BT_SLEEP_CLK N !NOT EXECUTED(03) 108 EXT_DEVICE N !NOT EXECUTED(03) 86 CDSP_RF_BB_IF N !NOT EXECUTED(03) 83 CDSP_RF_SUPPLY N !NOT EXECUTED(03) 85 CDSP_TX_IQ N !NOT EXECUTED(03) 74 CDSP_TXC_DATA N !NOT EXECUTED(03) 79 CDSP_RX_PLL_PHASE_LOCK N !NOT EXECUTED(03) 80 CDSP_TX_PLL_PHASE_LOCK N !NOT EXECUTED(03) 81 CDSP_RX_IQ_LOOP_BACK N !NOT EXECUTED(03) 77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03) |
04-18-2011, 10:19 | #3 (permalink) | |
No Life Poster Join Date: Feb 2007 Location: Pakistan Age: 36
Member: 447849 Status: Offline Sonork: 100.1604076 Thanks Meter: 593 | Do SX4 Auth Write Modified RPL Pm Field 1 - 309 B.r., Sonu Quote:
04-18-2011, 12:05 | #6 (permalink) | |
Freak Poster Join Date: Nov 2009 Location: ASSANDH(KARNAL)HARYANA Age: 32
Member: 1169871 Status: Offline Thanks Meter: 175 | Quote:
http://forum.gsmhosting.com/vbb/f550...ution-1044092/ | |
04-18-2011, 12:09 | #7 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | not all security test fail r due to software problem it's also cause by hardware problem. but first make backup only npc data (imei) then full erase d flash using untick on safe erase option on mx-key (as u r using mx-key) . after that flash ur set with latest firmware , restore npc date & also restore other certificates via security server of mx-key. repair sd , make sx4 auth & write pm 1,309 . post here d result mate. |
04-18-2011, 13:35 | #8 (permalink) | |
Insane Poster Join Date: Mar 2011
Member: 1541412 Status: Offline Sonork: just beside u....... Thanks Meter: 25 | Quote:
04-20-2011, 16:39 | #13 (permalink) |
No Life Poster Join Date: May 2008 Location: P@Ki$t@n
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | follow steps 1.Backup Just NPC Data rpl (only npc data) Or recover cert with HWK. 2.Full erase With erase file (BB5Erase_8MBrap)with hwk after erase full flash and ui setting then 3.write backup Just Npc Data Rpl Not hwc ccc data just NPC data. 4.Then repair sd and simlock 5.Then write full pm with pmauth ur problem solve i teset this many time with security test fail problem when its not done with any thing. |
Security Code | dESiRE! | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 05-13-2011 22:17 |
5110 Security Code Help! | cahrisma | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 07-05-2010 09:04 |
Nokia 5110 v. 5.24 Unlock Failed! | Cybertooth | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-28-2000 15:35 |
SECURITY CODE | AWLABA | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 02-22-2000 23:38 |
Mti init failed | dogbreak | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-22-1999 01:28 |
