Old 04-17-2008, 09:42   #1 (permalink)
vishal123123's Avatar
Member: 463150
Thanks Meter: 91
3110 c charge not save
3110 c showing charging but charge not save. i have changed the charger and the battery also but same problem. charge not save....... . i have checked the lines its all ok.......
The Following 4 Users Say Thank You to vishal123123 For This Useful Post:
Old 04-17-2008, 11:23   #2 (permalink)
Member: 752365
try to change charging ic
The Following User Says Thank You to gulshan chopra For This Useful Post:
Old 04-24-2008, 12:13   #3 (permalink)
Parminder Singh's Avatar
Member: 476739
Thanks Meter: 507
ZDIOD 3.9V -SIDE CHARGING SOCKET ATACH + ZDIOD +SIDE ATACH BAT.+ POINT CHEK VOLT.. THEN CHARGING
ENJOY
The Following 4 Users Say Thank You to Parminder Singh For This Useful Post:
Old 04-24-2008, 15:48   #4 (permalink)
Member: 641166
Thanks Meter: 331
change tahvo and your problem will slove 100% tested
The Following User Says Thank You to galant2 For This Useful Post:
Old 04-24-2008, 16:28   #5 (permalink)
hanen's Avatar
Member: 70053
Thanks Meter: 85
try this if same pro change tahvo ic
The Following 5 Users Say Thank You to hanen For This Useful Post:
Old 04-24-2008, 16:46   #6 (permalink)
shivashakthi's Avatar
Member: 594753
Sonork: 100.1605626
Thanks Meter: 822
3100 charging
3100 charging ........
The Following 6 Users Say Thank You to shivashakthi For This Useful Post:
Old 04-24-2008, 17:36   #7 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
U have to change the battry.
OR check this link
http://forum.gsmhosting.com/vbb/show...77&postcount=5
http://forum.gsmhosting.com/vbb/show...35&postcount=6
Post result.
The Following 2 Users Say Thank You to amol_sm For This Useful Post:
Old 04-24-2008, 17:38   #8 (permalink)
jasimbinrashid's Avatar
Member: 542150
Thanks Meter: 126
i have also same 6300 same problem?
Old 04-24-2008, 18:53   #9 (permalink)
smartengghelp's Avatar
Member: 740993
Thanks Meter: 75
its thavo ic problem
The Following 2 Users Say Thank You to smartengghelp For This Useful Post:
Old 04-25-2008, 04:44   #10 (permalink)
Member: 255862
Thanks Meter: 8
[B][/B]FAREST tray to romov mmr card and flash the phan
The Following User Says Thank You to moatafa For This Useful Post:
Old 05-22-2008, 19:05   #11 (permalink)
Member: 429983
Sonork: 100.1604691
Thanks Meter: 59
hi replace tahvo its work
The Following User Says Thank You to khansahab For This Useful Post:
Old 05-26-2008, 14:37   #12 (permalink)
Member: 227338
Thanks Meter: 25
here is Brother the soultion
it 'll help you
The Following 6 Users Say Thank You to al3oshak For This Useful Post:
Old 05-26-2008, 15:40   #13 (permalink)
FEATURE GSM™'s Avatar
Member: 276151
Sonork: 100.1577032
Thanks Meter: 234
thank yoU hi replace tahvo its work
The Following User Says Thank You to FEATURE GSM™ For This Useful Post:
Old 05-28-2008, 11:08   #14 (permalink)
Member: 777130
Thanks Meter: 3
hai friend 6233.ring sound no sherpnesh. new ringear change .but same pro.. please helf
The Following User Says Thank You to idhayammobiles For This Useful Post:
Old 05-28-2008, 12:07   #15 (permalink)
Member: 283763
Thanks Meter: 102
i have 5610 with same problem pl help me
thanks
The Following 2 Users Say Thank You to ruvanw1979 For This Useful Post:
nokia n73 showing charging but charging not save shree59 Nokia Hardware & Hardware Repair 24 04-11-2014 07:54
Nokia 6500c fake charging.charging not save solution mahbubalfa Nokia Hardware & Hardware Repair 12 05-08-2011 10:47
N95 8GB Charge ok but charging not saving buy_new Nokia Hardware & Hardware Repair 9 11-23-2010 14:18
x100 charging not save i chang charging ic but same shani72 Samsung Hardware Repair 0 03-31-2009 15:07
N95 8GB Charge ok but charging not saving urgent Adil Mobiles Nokia Hardware & Hardware Repair 8 10-08-2008 20:52
Page generated in 0.21761 seconds with 10 queries
