3110 gets off in 4 minutes in music player got a 3110c, it works well in normal condition. But if I play music player, it goes off injust 3-4 minutes. I've flashed it using JAF, Hwk, but still same. To check whether its mmc ic problem, I'd copied a song to phone memory and played it thru musicplayer but then also same........what to do now?????/ plz help?????? anybody got any idea????// |
selftest the unit usng jaf then run all then post the log to read the problem. |
show post log plzz after selftest |
log please................. |
imei is ok problem Superdongle key invalid repair MT or Universalbox ( Need ...$ ) http://forum.gsmhosting.com/vbb/showthread.php?t=886254 |
flash with latest version if problem is not solved than post the log here |
I've done selftest through jaf, all tests get passed, checked imei too, its ok............ But board is little bit bent at the usb section and two drivers R2007 & N2031 are got removed......... does it matter????/ |
plz help me sir 3110c auto off in music player log here CMT Boot Data: Asic ID: 000000010000022600010006010C192101001101 Asic Mode ID: 00 Asic EM ID: 00000353 Asic Public ID: 1DA0000832537B56186AC31A719EFDCBBD34C59A HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 191EC665DFAAF68F CMT Boot File: C:\Program Files\ODEON\JAF\Flash\UFS\rap3gv3_2nd.fg Loader version: 01.10.02 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 881C0020 <=> ST -> M39L0R807 CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\UFS\RAP3Gv3_algo_fps8.fg Loader version: 01.0C.05 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready Done! Restarting phone...Done! |
use mxkey Complete repair damaged simlock by MXkey except SL3: 1. Backup RAP NPC Service > Imei & Security > Imei Rebuild: Section, Select RAP > Backup RPL 2. FULL ERASE Flash > Advance : untick safe ERASE > Erase Flash 3. Flash MCU,PPM,CNT 4. Restore IMEI Service > Imei & Security > Imei Rebuild > Restore Imei 5. Repair SPLock Service > Imei & Security > Simlock : Repair Simlock > Repair SPLock 6. Repair SD Service > Imei & Security > Imei Rebuild > Repair SD 7. Super SD Auth Service > PM > Super SD Auth 8. When super SD auth is done, write PM imediately. |
dear it gets off in 2 min and some second and which boxes do you have just give name according to them i will give solution |
dino dear supar dongal corrupted repair with mx key & univarsal box i am tested 100% |
pls flash with good file n also check memory card ic black |
Its 100% supardongal corrupted. repair it with mx key |
Before asking any help please post full Operation Log............................ |
I have same problem in 2 handset please help me any body have solution of this problem |
