Old 02-09-2010, 09:35   #1 (permalink)
Member: 1137967
Thanks Meter: 34
3110c CHARGER NOT SUPPORTED
Hello friends
i have 3110 showing charger not supported
i changed 47k resistance but still the same
somebody plz help
The Following User Says Thank You to Vicky Matharu For This Useful Post:
Old 02-09-2010, 09:45   #2 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
Originally Posted by Vicky Matharu View Post
Hello friends
somebody plz help
@Vicky Matharu
try to change tahvo ic .....
Old 02-09-2010, 09:54   #3 (permalink)
Member: 1137967
Thanks Meter: 34
Whare is it located on the board
Old 02-09-2010, 10:01   #4 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
@Vicky Matharu
check this pic....
Old 02-09-2010, 10:32   #5 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,808
use sx4 pm 1st chk then try alll
The Following User Says Thank You to gopalhot For This Useful Post:
Old 02-09-2010, 10:40   #6 (permalink)
Ligalig's Avatar
Member: 1079935
Thanks Meter: 511
i agree with you sir. try to write good pm your problem is solve
Old 02-11-2010, 07:58   #7 (permalink)
Member: 1137967
Thanks Meter: 34
guys i wrote ok pm but problem is still the same
Old 02-11-2010, 08:04   #8 (permalink)
smorbe's Avatar
Member: 132735
Thanks Meter: 88
do you have mxkey?..check if SD in invalid,i encounterd same problem.
if its invalid,do pm auth and write pm 1 and 309.
if all is passed and valid,then you may continue hardware repair.
br
smorbe
Old 02-11-2010, 08:10   #9 (permalink)
Member: 1199105
Thanks Meter: 7
check btemp...
br.
Old 02-11-2010, 08:11   #10 (permalink)
$h@hidmobile$'s Avatar
Member: 652132
Thanks Meter: 146
Hello friends
somebody plz help
brother first write good pm , if same problem then again change 47k resistance with good one
Old 02-11-2010, 08:19   #11 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
Hello friends
somebody plz help
Bro.write pm file with mt box.
Old 02-11-2010, 11:25   #12 (permalink)
hermanpatel_14's Avatar
Member: 894345
Thanks Meter: 27
put the 47k resistor in perfect way. also check it when u put resistor only one side of resistor should be gnd. not both.
nokia 3110c charger not supported. Teepat Nokia Hardware & Hardware Repair 29 11-21-2011 14:14
3110c charger not supported Maninder_111 Nokia Hardware & Hardware Repair 2 03-08-2010 12:33
3110c charger not supported rajendrakumar Nokia Hardware & Hardware Repair 14 02-04-2010 16:06
3110c charger not support kiran Nokia Base Band 5 ( BB-5 ) 6 10-09-2009 18:29
3110c charger not supported miharajmiju Nokia Hardware & Hardware Repair 4 06-18-2009 15:32
Page generated in 0.24314 seconds with 10 queries
