3110c - generate magic problem Hallow sir Today I got new problem in 3110c MICRO - data BLK error UB - with USB - boot ok but cannot flash - with Fbus - boot ok but flashing error JAF - sync error when hit on check - but I suddenly hit flash button set can flash completely without error . this is magic by jaf . But another problem create 1. After flash set normaly start on computer but after 10 to 20 sec set go in LOCAL MODE with bright screen 2. but set can not start with battery What is this problem sir |
some water dameage in battery canector |
some body say me why jaf complete this work easyly but not MICRO , MXkey , also UNIVERSAL why whas it cause |
Hurrey Hurrey Hurrey I make this set by MXkey + 7.30 ver 1. When re wash & rehot set comes in LOCAL Mode . 2. Flash it 7.21 no any changeg . Set start on computer and after some time set go in Local mode with white screen . set cannot start with battery . when charger conected show charger not supported . SOLUTION 1. Flash with 7.30 ver 2. Backup RPL 3. Reset NCP 4. Write RPL 5. Repair SD 6. Load 1 & 309 PM 7. Hit SUPER SD Auth 8. Write Pm . MY SET WILL OK AHD ALL FUNCTION WORK PRPPERLY LIKE 1. Charger Not Suported 2. SET Not start with battery 3. LOCAL MODE with white screen . UB cannot boot in fbus mode & also USB mode very bad |
Generally the problem comes with flashing cable change flashing cable u and then u can flash with jaf,micro usf etc it easily flashes |
