3120 c cmt error can help plz....... 3120C FLASHING LOGO ON DEAD USB IN JAF I try f bus cable same Fhone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-365\rm364__09.41.mcusw PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-365\rm364__09.41.ppm_f CNT Flash file: NONE APE Variant file: NONE Languages in ppm: English,German,Hebrew,Arabic,Russian Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-365\rm364__09.41.mcusw PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-365\rm364__09.41.ppm_f CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-365\rm365__09.41_ISM_009.image_f_chestnut_brown APE Variant file: NONE Languages in ppm: English,German,Hebrew,Arabic,Russian Detected P-KEY: 9002A24C P-key nokia module version 01.02 Init usb communication... PRESS POWER ON NOW! Searching for phone...Found Sending RAW loader... Using 06.02.002 Elf2flash 07.14.000 CMT RAW loader... Patching RAW boot step1... Patching RAW boot step2... Patching RAW boot step3... Sending RAW Loader... ...................Loader Sent! Stage 2 starting.......................................... ...................................Loader Sent! Stage 3 starting..................Phone prepared OK! Waiting for the phone to boot... Searching for phone... Phone failed to boot in flash mode CMT... help me plzzzz......... |
Bro...use 7pin cable...& flash... if not ok.. rehot flash ic.................. |
sir, plz.... give me explained diagram .............. |
3120 c sir, plz.... give me explained diagram .............. |
.................................................. ........... use proper cable cmd error is normally cable fault |
ashad bhai giv me location of flash ic 3120c......... |
ur flash ic ok its ur cable problum usb 7pin ok cable |
i have try the usb .ufs cable. univesal cable problem is same to also cmt ero |
bro change the cable i had same problem .... |
I have same problem with.i've reball ic flash,rap.but the problem still "phone failed to boot in flash mode CMT....". any other solution? |
