Old 02-01-2007, 17:09   #1 (permalink)
Member: 229274
Thanks Meter: 147
Thumbs up 3120 Network Problem- Experts Only
Hello Experts
Dear Friends
I Have Got A Handset From My Friend,
He Is Expert, But He Cant Solve It
I Am A Beginer To This Field
I Know Basics, I Want To learn Now
Here Is A Problem Solve It
My Friend Got A Handset 3120 Network roblem, He Was Not Able To Solve It, He Followed These Steps
1. changed Antena Switch
2. PF IC Changed
3.All Tracks Are Checked
4.Power Supply IC (reoiled)
5.Klashed With UFS- Saras SOft
6.And He Did Network Software
Please Solve This Problem,
Thanks In Advance
The Following User Says Thank You to serchingeye For This Useful Post:
Old 02-01-2007, 23:21   #2 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
3120
Originally Posted by serchingeye View Post
Hello Experts
Dear Friends
2. PF IC Changed
Thanks In Advance
dear i think there is mjolner IC fault see my pic , before this check supply of PA ,
The Following User Says Thank You to r a nadeem For This Useful Post:
Old 02-02-2007, 10:35   #3 (permalink)
Member: 101007
Thanks Meter: 27
fo my exeperience most of 3120 3100 network prob
cause by mjolner as the graph above
reball reheat or replace but most of it replace would be a better option
if reheat will only solve ur prob temp... reball as well
replace can last longer but don expect tis prob will solve 4ever
cuz tis prob mostly cause by the bga ball came off from the board due to nk manufacturer prob.. tis phone when u put inside pocket or slightly twisted the board will giv u tis prob... uem are one of the pain in the a** prob too ...
regards
The Following User Says Thank You to uneternity For This Useful Post:
Old 02-02-2007, 10:58   #4 (permalink)
Member: 432364
Thanks Meter: 270
May be you have not changed antina swich correctly tri to change again
otherwise make a antina switch jumper like picture.
B.r.
psunil.
File Type: jpg 3100 6100 antina switch from prakash.jpg (75.2 KB, 144 views)
The Following User Says Thank You to ..::Sunil::.. For This Useful Post:
Old 02-02-2007, 13:22   #5 (permalink)
Member: 229274
Thanks Meter: 147
Thanks For Replay
I Will Try
If AnyBody know Exact Solution For This
Please Reply To This Post
Old 02-02-2007, 13:36   #6 (permalink)
Member: 160579
thankx friends.
goood
The Following User Says Thank You to midou_gsm For This Useful Post:
Old 02-02-2007, 13:38   #7 (permalink)
Member: 302945
Thanks Meter: 14
try wit hot air UEM i.t the problem
The Following User Says Thank You to thiess For This Useful Post:
Nokia 3120 Network Problem ramdev_mobbile Nokia Hardware & Hardware Repair 3 07-13-2010 08:46
nokia 3120 network problem manou_patou Nokia Hardware & Hardware Repair 6 09-10-2007 05:37
3120 Network Problem noufalrv Nokia Base Band 5 ( BB-5 ) 5 09-02-2007 20:26
nokia 3120 network problem pradeep agrawal Nokia Hardware & Hardware Repair 6 03-24-2007 06:19
nokia 3120 network problem pradeep agrawal Nokia Hardware & Hardware Repair 1 06-29-2006 04:28
Page generated in 0.19842 seconds with 10 queries
