01-01-2008, 17:34 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: UAE
Member: 420857 Status: Offline Sonork: 100.1576793 Thanks Meter: 1,734 | 3120 ringtone problem I have heated IC N150 and checkd the spaeker also. plz anyone help me. thanx in advance |
01-01-2008, 18:24 | #3 (permalink) |
Registered User Join Date: Apr 2007
Member: 483748 Status: Offline Thanks Meter: 47 | U SAID IT WORKS WHEN I PRESS THE BOARD OTHERWISE IT IS NOT WORKING.IT HAS MANY SOLUTIONS ONE OF THEM IS TO REBALL UEM IF PERSIST THEN 2ND IS REBALL UPP.UR PROBLEM WILL BE SOLVE IF U FOLLOW THE SEQUENCE. |
01-02-2008, 20:41 | #4 (permalink) |
Insane Poster Join Date: Jan 2008
Member: 669218 Status: Offline Thanks Meter: 11 | 1st check the tracks from ringer ic to ringer pins, then replace new ic with most carefully or place ur board in other inner body of running set to check may be inner body fault. thanxxxxxx |
01-03-2008, 03:17 | #6 (permalink) | |
Freak Poster Join Date: Mar 2007
Member: 465901 Status: Offline Thanks Meter: 45 | Quote:
Good Luck | |
Nokia 3120 Network Problem | ramdev_mobbile | Nokia Hardware & Hardware Repair | 3 | 07-13-2010 08:46 |
3120 ringtone problem pls help me? | shimul_777 | Nokia Hardware & Hardware Repair | 1 | 10-04-2007 06:09 |
3120 charge problem | jak2812 | Nokia Hardware & Hardware Repair | 4 | 12-29-2005 15:57 |
3120 hanging problem | yandbass | Nokia Hardware & Hardware Repair | 1 | 08-03-2005 06:33 |
3120 upgrading problem | chetangajjar | UFS2 + UFS3-Tornadoflasher | 5 | 01-18-2005 09:07 |
