Old 05-27-2008, 09:32   #1 (permalink)
Cheater -Don't Deal with him-
Member: 622382
Thanks Meter: 201
1110i lcd blank .......after few minutes
i have problem 1110i set. set is ok but few minutes letter lcd is blank. when is lcd blank call not incoming pr not outging.i flash latest verson by mtbox and jaf . plz help me . plz help me any one emargency. advance thanks
Old 05-27-2008, 09:39   #2 (permalink)
techouse's Avatar
Member: 155454
Thanks Meter: 18
check lcd conector, check ways
Old 05-27-2008, 09:46   #3 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
plzzzz help
how can change imei whith jaf but any problem plz help guys
Old 05-27-2008, 09:59   #4 (permalink)
Registered User
Member: 646178
Thanks Meter: 32
when that problem occures after flashing or before? if before then check and change LCD CONNECTOR
Old 05-27-2008, 17:54   #5 (permalink)
Member: 622382
Thanks Meter: 201
any one corect information.................
Old 05-27-2008, 18:42   #6 (permalink)
NIMESHFONOTLY's Avatar
Member: 760274
Thanks Meter: 146
I THINK THIS IS AHARDWARE COMPLAINT.PLEASE TRY O REHOT FLASH IC THEN CHECK IT.BUT USE CAREFULLY.
Old 05-27-2008, 19:17   #7 (permalink)
mobilespeed's Avatar
Member: 706300
Thanks Meter: 147
re:
" bro if u mean after sometime display gets blank & call not possible, then the culprit is upp,but tell me when u again press the on/off button wt happens i mean blank diplay or normal on,thanx"
Old 05-27-2008, 21:12   #8 (permalink)
FEATURE GSM™'s Avatar
Member: 276151
Sonork: 100.1577032
Thanks Meter: 234
Exclamation
her is the bro if u mean after sometime display gets blank & call not possible, then the culprit is upp,but tell me when u again press the on/off button wt happens i mean blank diplay or normal on,thanx"
Old 05-28-2008, 05:52   #9 (permalink)
Member: 622382
Thanks Meter: 201
when off/on set is normal discplay.but few mintues letter blank discplay
Old 05-28-2008, 06:01   #10 (permalink)
Member: 482362
99% LCD Problem......,,,,
Old 05-28-2008, 06:02   #11 (permalink)
aboymaligalig's Avatar
Member: 460316
Thanks Meter: 22
have you check the imei sir? if imei is good then you must go hard ware rehot uem hope this may help
Old 05-28-2008, 06:06   #12 (permalink)
Member: 706300
Thanks Meter: 147
re:
"bro, check the voltage ( vflash c2402 2.8v& vio2403 1.8v) if they remain ok after the problem, then work on upp if u find voltage is dropping then give voltages to it,thanx"
Old 05-28-2008, 06:08   #13 (permalink)
VIBINDAS_INDIA's Avatar
Member: 707582
Sonork: 100.1620432
Thanks Meter: 334
this problem related upp.
1st time u change RTC & cristal then not ready?
next do rehot, reball.or replace upp
good luck br
Old 05-28-2008, 06:49   #14 (permalink)
Member: 778895
chnage lcd brother once i faced this problem i chang the lcd from an workin fone and solve the problem
Old 05-30-2008, 09:09   #15 (permalink)
[Shadab_M]'s Avatar
Member: 238812
Sonork: 100.1602669
Thanks Meter: 1,443
First try different LCD. If it does not work, full erase and flash. Write PM. Do Ui setttings.
Tested by me.
Br,
Shadab Ahmad
Lcd Blank after Few time 100000000% ok 1200 1208 1650 marhabamobiles Nokia Hardware & Hardware Repair 15 04-20-2010 09:10
1200 going blank lcd after few minutes GSMBALOCH Nokia Hardware & Hardware Repair 14 04-04-2010 19:34
6600 LCD disappear in few minutes neppra Nokia Hardware & Hardware Repair 5 08-20-2008 07:52
NOKIA 7610 WHITE LCD after few minuts.... asrar Nokia Hardware & Hardware Repair 1 10-30-2007 00:23
3650 lcd blank after +- 15 minutes CellM@n Nokia Hardware & Hardware Repair 0 09-28-2005 10:30
Page generated in 0.26671 seconds with 9 queries
