3200 no network changed uem, after flashing hi found network,callig ok.Powered agen but no signal manual search no operator, and show that hands free conected, but not conected on the phone. Any idea. |
Soloved writen new PM but headphones not remuved. Signal was bad- low sesitive, found network neer base station |
Make full reset. GreetZ |
not work, thanks man anyway, i try to change N150 audio amplifier |
firsrst try sw re heat uem n reflow near system connector. it could also be faulty uem. its possible u have a dry joint cos of heatind board to much n lots of flux so re heat wit hot air only good luk |
Remove The Duplexer Check For Cracks Below. A 3310 Duplexer Can Replace That One. Do Not Bridge The Duplexer. (work Properly Not Like A Fool) Also Remove The Pa And Clean The Pads Below And Refit Properly. |
