Old 02-23-2006, 17:43   #1 (permalink)
Member: 6358
Thanks Meter: 10
6600 white screen and shutdown after 33s
This phone had display problems, after replacing display filter IC it worked.
But it has another problem, 33s after keypad lights go on during startup (when Nokia flashes), display goes white and phone goes off. You think it's UEM problem? Same thing happens if I remove display filter IC, phone goes off after 33s.
By the way, IMEI is ok and phone works fine, but only for ~30s
Best regards
The Following User Says Thank You to fontelense For This Useful Post:
Old 02-25-2006, 11:13   #2 (permalink)
Member: 46304
Thanks Meter: 2
hey man try this full erase 6600 flash mcu+ppm+cnt128+unlock after flash and ui setting also try to format user area works 100% for me also try this on to manual format phone (send key+*+3+power on )
The Following 2 Users Say Thank You to cellspeed For This Useful Post:
Old 02-25-2006, 13:25   #3 (permalink)
Member: 6358
Thanks Meter: 10
Thanks for trying fo help, but honestly I don't think you understand what I'm talking about.
Old 03-03-2006, 10:09   #4 (permalink)
Member: 239168
Thanks Meter: 104
in our experience it is due to current sense monitor ic Z304
Old 03-03-2006, 12:32   #5 (permalink)
Member: 6358
Thanks Meter: 10
There's no Z304 in 6600 service manual, have you mistaken it with some other component?
Old 03-03-2006, 23:27   #6 (permalink)
Member: 144154
Thanks Meter: 9
software problem
try higher version
or ur problem with cpu
Old 03-03-2006, 23:48   #7 (permalink)
SRNOURI's Avatar
Member: 29870
Thanks Meter: 24
If your phone go off after 30s ,the reasn is UEM.But befor change it try to make a rpl of this uem and write it to that.If this could't solve your problem then you should change the UEM IC
Old 03-04-2006, 06:21   #8 (permalink)
Registered User
Member: 200823
Thanks Meter: 7
if your phone 6600 format *3 ok batune and power on.+screne target format..................................../
Old 03-04-2006, 08:01   #9 (permalink)
hangout2511's Avatar
Member: 37352
Thanks Meter: 278
UEM Problem ... change UEM .. tested solution
Old 03-04-2006, 09:07   #10 (permalink)
goffaman's Avatar
Member: 164237
Thanks Meter: 12
Best regards
is UEM problem.. based on experiene its the same problem with 2300,1100, and 6230. you can retain your imei after changing UEM but dont chane it first.. use JAF imei tool to save your imei and ask file then you can change it.. hope i did give you a bit of help my friend..
Old 03-04-2006, 09:33   #11 (permalink)
waleed2's Avatar
Member: 85387
Thanks Meter: 78
so whats solution we are waiting i dont think it need to change uem maybe if you read full pm using ufs then convert it to rpl using pmtorpl then instale rpl to phone then try and post replay
Old 03-04-2006, 10:26   #12 (permalink)
Member: 239168
Thanks Meter: 104
sorry.ic R385 near batt.contact in ckt(near camera in motherboard)
Old 03-04-2006, 19:23   #13 (permalink)
Member: 45635
Thanks Meter: 20
..........uem...................
Old 03-04-2006, 19:30   #14 (permalink)
Member: 234374
3660 after flash no network any body helpme tnk
Old 03-04-2006, 22:41   #15 (permalink)
SRNOURI's Avatar
Member: 29870
Thanks Meter: 24
Dear friend, we are talking here about 6600 white screen problem.you should ask your question i new topic.
WBR.
w810..white screen and vobration after flash!!! hicvb7 Cruiser Suite 13 04-11-2007 08:14
6600 white screen and erasing failed???? sallu Nokia Hardware & Hardware Repair 3 02-13-2007 17:51
6600 white screen and switch off ziko WD2 & APE (Symbian Phones) 1 04-18-2005 16:01
6600 white screen after tornado flash ckkckk WD2 & APE (Symbian Phones) 1 03-25-2005 14:30
Page generated in 0.48747 seconds with 10 queries
