3210 not charging displayed Hi I have 2pcs of 3210 with this problem "not charging" displayed if I connect charger. I changed BGA N100 and N101 (ccont)but problem is the same still "NOT CHARGING".<br />Please can anybody help me? <br />thanx in advance<br />Vicky |
Vicky..tell me what happens if the phone is off & then u plug charger in so i can understand yr exact fault. <img src="wink.gif" border="0"> |
Check yr mail,Vicky...hope u understand!!! <img src="wink.gif" border="0"> <img src="wink.gif" border="0"> |
Hi Fizz,<br /> If phone is off and I plug charger the battery indicator is only flashing. If I switch on...not charging displayed. Without battery I measure on bat. pins 2.8V. <br /> thx for your mail I'll try resolder capacitors between batt. pins<br />regards Vicky |
wow....I change capacitors and now charging is ok...how easy solution..<br />thanks for your help<br /> best regards<br />Vicky |
Hi!<br />I have this problem too with my phone!<br />Can you explain me, or send a mail with this info? Thanx.<br />iHi |
WELL DONE VICKY!!There's no end 2 learning!! <img src="wink.gif" border="0"> |
hi cells r us<br />I have same problem with 8850<br />says not charging<br />can you please help me out here ? <img src="frown.gif" border="0"> Thanks in advance greetings <img src="wink.gif" border="0"> |
Hi all...I have not seen any charging faults on 3310 88xx except 3210,that were out of the ordinary..I will post solutions to all charging probs in previous posts as soon as i get those exact faults in 4 repair. <img src="biggrin.gif" border="0"> |
hi cells r us, pls send me also the solution for not charging, thanx in advance. pls send to [email protected] |
Hi AOS..check yr mail..hope it helps.. <img src="wink.gif" border="0"> |
2 cells r us.<br />Please send me also the solution for not charging (3210). I shall send you solution for 3310 (if it is necessary for you).<br />Thanx <br />[email protected] |
Hey Fizz and Guest, could you please send me the repair tips for not charging problems? Thanks m8s. |
cells r us, thanx ill try in my unit |
