Old 02-26-2003, 16:25   #1 (permalink)
Finn's Avatar
Member: 7731
Thanks Meter: 27
8850 problem
I have an 8850 and it dont turn on
I can read/write flash.There is no checksum problem
Old 02-26-2003, 20:44   #2 (permalink)
Springer's Avatar
Member: 15909
Hi
Change 26Mhz crystal oscillator,
test it
If no good, Change CCOnt,
test it
if not work,
Reball or change Hagar.
Try it!
Old 02-26-2003, 20:56   #3 (permalink)
Member: 1060
Thanks Meter: 10
If you can flash phone, and can read it too ...
all system clock must be working !
try plug charger , see what happen !
or try to give 2.8V to Btemp with in 1 sec to boot up phone !
or check BSI resistor value !
if all not help,, replace MAD or flash rom !
Willy
Old 02-27-2003, 20:04   #4 (permalink)
Finn's Avatar
Member: 7731
Thanks Meter: 27
Willy thanx for reply
I tried to charge it but it doesnt charge.
I ll try the other thing syou said
Old 02-27-2003, 21:52   #5 (permalink)
Member: 3202
Thanks Meter: 6
Check or replace 32.768 kHz crystal.
I have had exactly the same problem with 8210.
Old 02-28-2003, 23:17   #6 (permalink)
cmk
Member: 10387
Thanks Meter: 3
dct3 phone power on no need 32.768khz
Old 02-28-2003, 23:22   #7 (permalink)
cmk
Member: 10387
Thanks Meter: 3
if power on your phone is 3 6 9 key open circuits
Old 02-28-2003, 23:24   #8 (permalink)
cmk
Member: 10387
Thanks Meter: 3
or try use power supply set to 4.2v to test
Old 03-01-2003, 22:40   #9 (permalink)
Member: 3202
Thanks Meter: 6
Hi cmk
Have you ever try to turn on dct3 phone without 32.768 kHz crystal?
Finn can read/write flash but can't turn on...
Old 03-01-2003, 23:00   #10 (permalink)
kulibin's Avatar
Member: 16452
Thanks Meter: 4
Dct3 phone turn on without 32.768 kHz crystal
I think rehot PCB
8850 problem gazt Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-01-2002 23:59
Nokia 8850 problem italianboy Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 03-28-2002 04:39
Nokia 8850 problem italianboy Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 02-28-2002 04:19
8850 problem network alpha Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 12-02-2001 21:39
8850 problem free_gsm Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 05-11-2001 17:54
Page generated in 0.23060 seconds with 9 queries
